Hi all,
I attended a call last week for an MPC2004 giving intermittent SC120-00 (HP Error). After checking motors and sensors in engineers mode, checking drive belts, lubricating rails etc. I removed the scanner drive motor.
Although it runs correctly in engineers mode about a quarter of the adhesive on the black rubber ring on the motor had come off, causing it to flex a tiny amount. When the scanner unit is moving from right to left at the home position the load must of been just a little to much on occasion which gave the SC120-00 code.
I'm still pretty new to Ricohs but from what I can tell the IMCs use the same drive mechanism so this may be useful for someone in the future.
Thanks.
Thanks.
