Firmware update "E71" multiple models
  • sandmanmac
    • 3967
    [Error Code] Firmware update "E71" multiple models
    As the title says, I get this error quite often on machines I pick up for resale; However, it seems to be more prominent on some - for example, I'm not sure I've ever had an MP C306 that didn't generate this error, and most of my MP501's do too.
    The same machines also fail if I visit the Application site and try that way, but it just says something like "server unavailable"
    I've looked around and just can't find much info on this one.
    Most recently, I picked up 5 of the IM 430F machines from the same end user.
    All units were configured seemingly identically, and were all used on the same network.
    3 of the 5 units give me an E71, and 2 went through the process and updated properly via SP mode.
    This is by no means a huge problem as I have access to the firmware to do it manually, I'm just interested/ curious to know if anyone has insight into why some work and some don't?
    Thanks!!
  • davidmtupper
    • Jul 2021
    • 326
    Re: Firmware update "E71" multiple models
    It may have to do with what firmware is currently on the copier. Some of the early firmwares had the option for network update but it wasn't actually usable until a later firmware was installed. This may or may not be the case with your systems but I have had it happen to me.
    • sandmanmac
      • 3967
      Thanks.
      I think that can sometimes be the case, but as I said, I can update manually, but the SP mode update stills gives the same error
        • 36688
        In order for the SP mode firmware update to work, there are other things that have to be set first to tell it where to get the firmware. One time in just one model I did see a list of the communication error codes you could encounter using the SP firmware update option but I can't remember what model it was. I can't even remember if it was B/W or Color. I do remember that 71 was one of them.
        • GIUBOSS
          • 1382
          E71 Network connection error
          Auto Remote Firmware Update Settings
          • sandmanmac
            • 3967
            Thanks for this.
            I'm wondering if these are the settings required for older boxes, prior to models with SOP? (I'm unable to X-Ref the MT-C6 to determine the model #).
            While I know nothing about Proxy Servers, and don't have any credentials/ permissions to setup or use @remote, I can say that some of the SP modes (Ie: SP5-819-062) don't exist, and none of the other proxy SP's are configured - either on machines that update properly or that display the E71, error so I don't think this is my solution in this case.
            • DRichard
              • May 2008
              • 482
              Thanks!!
              I can usually get past this by updating the engine and system copy modules first, then updating the rest of the modules, all or package files afterwards. You might also try the previous versions as they are available, THEN do the current version after.
              "Enjoy every sandwich."
              -- Warren Zevon
              • sandmanmac
                • 3967
                Just to be clear.....
                I am able to update the firmware with SD card with either package or romdata files without issue, I'm just unable to use the SP mode or Application Site to update the firmware on many machines.
                Again, while it's not a big deal at all, I'm just curious when I have acquired multiple identical models from the exact same location, why I'm able to update some in that fashion, and the others error out?
                I do appreciate the input.
                  • 36688
                  Sounds like something the previous dealer had setup like @Remote and did not get it removed on al of them.I believe the SP mode Update actually uses the @remote server, but if the machine is configured to use a RCG, Remote Communication Gate, it will error if the RCG is not found. Check the setting of SP 5816-021 and 062.
                  • copier tech
                    • 8095
                    If you can update the firmware via Sd card with out any issues but you only have issues using the online update but ONLY at this same site I would speak to this site IT dept sounds like they have blocked ports etc.
                    As a simple fix to rule out client network connect a Ricoh device to dummy network tethered to your cell phone & initiate a network update.
                    This will run the update outside of the client network environment.
                      • 36688
                      I think that he has a bunch of used machines he is wanting to update in his shop before placing them with new customers. Normal operation here in the colonies. He is his own IT department.
                      • sandmanmac
                        • 3967
                        That's exactly what I'm doing.
                        These machines at one point or another are all connected to my own network for testing, updating, etc. and I'm just trying to find an answer to what seems to be turning into a more difficult question than expected.
                        • Ricoh-ono
                          • 339
                          E71: Network communication error occurs at the reserved date/time of the package firmware update from the network.
                          Ricoh had a problem with the "Network Support" file in a particular package firmware update. There was a problem across multiple models including the ones you listed. After the "Network Support" firmware piece is updated, the "device encounter fax document" disappears. Once Ricoh found the error it unpublished the package firmware worldwide including the Application site. I believe there were some TSB's published as to which package firmware versions to avoid. I'm sure there are machines in the field that have these "corrupt" versions and were never updated. Hopefully, this might explain some of the reasons for the E71 error.
                          Do what you can, with what you have, where you are. ~Theodore Roosevelt
                          • sandmanmac
                            • 3967
                            These are not scheduled updates. I'm trying to manually update via SP mode
                            Again, I currently have 5 of the IM430's at my shop (for example), purchased from the exact same location.
                            I can't say that they all had the exact same firmware modules, but I'm fairly they sure they were at least very close, as they were all purchased from the same dealer, and installed at nearly the same time.
                            3 were giving E71 errors when attempting to update via SP mode, and 2 of them I was able to update either via SP mode, or the App site.
                            I updated the 3 machines manually, and the other 2 via SP mode. They now have all the exact same F/W levels, yet I still have the same E71 on 3 units.
                            • Ricoh-ono
                              • 339
                              Understood. According to Ricoh, this E71 occurs when the firmware is updated via the following methods: Application Site, Streamline NX v3, Device Manager NX Pro/Enterprise, and Service Menu (SP Mode). Why you still have it happening on 3 of the 5 machines after the update, I can't answer.
