Ricoh C751EX Printer Fatal Error
  • cmitch
    • 50
    This is a back up machine for our 7110EX that hasn't been much of a back up lately (7110EX down because K dev unit took a s^$t and waiting on part). I'm getting this error on Fiery E41: Printer Fatal Error. The machine window says "Functional Problem Detected. Press 'Restart' after current process" with a progress bar. Twice it has done it today. I suspect we have a hardware problem since it was taken out of service right after we started getting this issue. I have 3 other fusers I can put in it in case that is the issue, which I read it COULD be one of the reasons BUT if I remember correctly, switching out fusers does nothing for the issue. Any ideas?
    EDIT: Make that 3. It just went down after 270 copies.
  • bojans
    • 1313
    Re: Ricoh C751EX Printer Fatal Error
    Did you check SC history? Which error code is there?
    • cmitch
      • 50
      It never gives me any alpha numeric codes. Just printer fatal error and the functional problem detected display.
        • 36130
        Check SC 5875-001 SC Auto Reboot. If it is set to 0 change it to 1. The machine will now display the actual SC code that it is stopping on. You will then know what to fix.
        • davel
          • Oct 2011
          • 1060
          I doubt he knows how to get into SP mode.
          • bojans
            • 1313
            In his profile, there is info that he was trained on this model.
            • davel
              • Oct 2011
              • 1060
              If so he would know how to look at SC history to see what
              the code is.
              • cmitch
                • 50
                Oh ye of little faith.
                Checked SP5875-001 and it was set to 0. I changed it to 1. Exited service, attempted to print. Coded out again. Printer Fatal Error. SC410. Drum Potential Sensor Black. I'll try cleaning the sensor first. Maybe it is dusty/dirty. Hopefully that's all it is. As soon as I get things rolling, I'll go check it.
                Thank you for your observation. We haven't run it regularly for 4 years. Just sporadic so not much has been needed so I'm a tad rusty.
                • bojans
                  • 1313
                  Thought it would be potential sensor.
                  You will have to change it.
                  You can use one from 7100 until you fix it (if you dont have spare parts)
                  Its a bit tricky, but you can change it only by removing PCU unit.
                  • cmitch
                    • 50
                    We rarely run it anymore but when we need it, we really need it. I think part is about $125. I vacuumed out cleaning unit and whole area around sensor. No go. Still coding out.
