Ricoh Pro C5100s Service Mode
  • Kozprint
    • 34
    Client bought from a broker and I'm unable to get in to service mode using Reset-806182-C hold. No admin lock. Even checked to make sure going to User Tools > System Settings > Administrator Tools > Service Mode Lock. Service Mode Lock doesn't exist on this one I can find.
    Last time I worked on one of these it was a few years older, is service mode code different on newer models or am I missing something?
    • 36855
    Re: Ricoh Pro C5100s Service Mode
    Service mode access code can be changed from with System SP. A common code used by those pissed about the new 6 digit code was the old 3 digit code entered twice. You might try that and also try or maybe ABCCBA where ABC is the old 3 digit code.
    • Kozprint
      • 34
      That was before my time so I don't know what that code was. Can you help me out?
      • Kozprint
        • 34
        Slimslob, Thank you I did remember some one telling me what the 3 digit code was and I'm in.
          • 36855
          I had read the same thing from someone else a few years ago. I was just the first one to see your post.
          • Kozprint
            • 34
            The sad part is I'm not sure how good this tech was. I've already replaced a wire harness and a board because they were to lazy to put a few screws back in and it pinched and cut a wire. Pulled the upper back cover and a fan fell out because the plastic where the screws went in is stripped. I'm just hoping that's the worst of it
            • Kozprint
              • 34
              Was hoping some one can help me out again. Can't get bit switches 5193 and 5895 to change for EFI communication. It's been a long time since I worked on one of these, what am I missing?
