Errore sc202 su ricoh mp9002sp
Re: Errore sc202 su ricoh mp9002sp
Hello everyone, thank you first of all for accepting me. I have a problem on my ricoh Mp 9002Sp, it practically goes continuously in sc 202 code, I read that it is the polygonal motor, I disassembled the development unit and the drum unit, I sucked up all the toner that could be attached to it inside the machine, I disassembled the polygonal engine I cleaned everything (I must say that I had done it other times and cleaning exactly as I am explaining afterwards it worked quietly) having previously reset the error when opening the machine, the code remains and the machine does not work. Today I opened the car from the rear I disassembled the fans and cleaned them I vacuumed everything that could be vacuumed I reassembled and reassembled everything but unfortunately the code still persists. At this point I would not know what to do anymore , so I await your technical news , thanks
REPLACE THE POLYGON MIRROR MOTOR.
And get a servide manual.
Follow the Forum Rules and post a request in English in the Service Manual Request forum.Forum Rules
General Rules
3. Service Manual Requests - All requests for service manuals must be made in the Service Manual Request Forum. Please read the special rules sticky in that forum for posting guidelines.Comment
Hi all guys, regarding the problem I encountered in the aficio mp9002 sp Ricoh error code sc 202, you advised me to change the polygon motor. I changed the motopre as recommended by you but the sc 202 hero still persists, honestly I don't know what to do anymore, do you have any advice on this??? Thank youComment
Try the door switches next.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Door switches are usually not a problem as the door safety only affects the laser unit and not the polygon, prevents the laser from being turned while the door is open.
Next items in the checklist are the Polygon mirror motor PCB (the board that the motor connects to), the IPU PCB and the harnesses that connect to the motor PCB.Comment
On an SP 9002 the door safety switches will not cause SC202. That solution is for older 35/45 page per minute machines where toner haze can get into the switches.Comment
