Ricoh Aficio MP 2022 scan FTP Setup for windows 10
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Misc] Ricoh Aficio MP 2022 scan FTP Setup for windows 10
    Hi friends, please help me to setup scan for Ricoh Aficio MP 2022 to windows 10 laptop.
    I try smb cannot.
    • 36685
    Re: Ricoh Aficio MP 2022 scan FTP Setup for windows 10
    The Aficio 2022, product code B089, was introduced about 20 years ago. It is too old to support USB v2/v3. It is no longer supported by Ricoh. That means that drivers are not available for Windows from Ricoh. THe only possible solution is to scan to Document Server and use WIM to download it to your computer. Otherwise what you now have is a boat anchor or will be when some part fails. Replace the dinosaur.
    • KeviM
      • Oct 2019
      • 324
      Agreed with Slimslob. Replacement is the best way forward.
      Perhaps you could try scan to email. That might work.
      All the best friend
        • 36685
        All the best friend
        f I remember correctly it will only support Port 25 SMTP. Does nor support TLS/StartTLS that almost all email services now require for security.
        • sandmanmac
          • 3967
          While I Agree that the machine is well beyond it's expiry date, the poster specifically asked about FTP, but then makes no mention of trying.
          Understanding that your location may make upgrading the machine a difficult task...
          SMB is definitely a no go, but Security vulnerabilities aside, it can absolutely scan with Filezilla FTP server or another free option.
          As for drivers.....you can print perfectly well using virtually any PCL 5e or 6 driver for any model you choose from the Ricoh download site.
          • rthonpm
            • Aug 2007
            • 2849
            It would be a good candidate for STunnel if they have to keep it.
            Overall, that's a machine from a very different era. It's time outside of print and copy to move onto a modern device.
            Sent from my Pixel 6 Pro using Tapatalk
            • kanagavel
              Service Engineer
              • Feb 2020
              • 78
              Friends i don't know how to do FTP.
              And one more thing is i can't login web image monitor
              I try admin, administrator, Supervisor
              But still cannot.
                • 36685
                But still cannot.
                What are you using as a password?
                • sandmanmac
                  • 3967
                  But still cannot.
                  I believe the default on that old machine was
                  U/N: admin
                  P/W: admin
                  I don't recall if the supervisor credentials were used in those days.
                  Unfortunately I don't have the time or interest in giving a step by step tutorial on an FTP server. Try YouTube
                    • 36685
                    U/N: admin
                    P/W: admin
                    That could be for the Ricoh Aficio models. It also might be ricoh. There was a time when for Ricoh Family Group lines (Gestetner. Savin, Lanier) it was savin. Savin was the main distributor for RFG. Default supervisor password might be the same. Of course it may have been changed. We had a couple of techs who when doing setup liked to change the admin password to the 3 or 4 digit model number.
                    • Elmo
                      • Feb 2010
                      • 541
                      This may help
                      I Used To Live To Fix Things Now i Fix Things To Live
                      • kanagavel
                        Service Engineer
                        • Feb 2020
                        • 78
                        I didn't use any password i just leave it empty
                        • rthonpm
                          • Aug 2007
                          • 2849
                          There was no supervisor account on these old machines. If I recall, the default credentials were no username and password as the password.
                          • kanagavel
                            Service Engineer
                            • Feb 2020
                            • 78
                            Originally posted by Elmo
                            This may help
                            Thank you friend.
                            • csliao
                              • Oct 2021
                              • 33
                              嗨,朋友們,請幫我設置掃描 Ricoh Aficio MP 2022 到 Windows 10 筆記本電腦。
                              我試試 smb 不行。
                              你可以試試 pcman ftp 或 quick easy FTP
                              opean or clouse windows function, FTP use
