Hi out there,
I know there has been some info about this before, but here goes...
I have an MPC 401 that has thrown an SC400 (ID sensor error). I cleaned the sensors thoroughly and re installed them and all was ok for a day and then the code returned.
I know that on the MPC307 - 45/5503 and 04 ranges there is a work around in factory mode to widen the perameters of the VSG check by (in factory mode) altering 3320-13 to 5v and 3320-14 to 1 v
this stops the code recurring and does not seem to have a detremental effect on copy quality until you can replace the sensors.
However, the 401 does not seem to have this perameter and I dont have one in the shop to look thru the menu, annoyingly the machine is 1.5 hours drive away, and I need to have the info to hand. Long term the thing is to change the sensor array, but I cannot lay my hands on one quickly - I would just like to get the customer working.
Any info would be welcome...
Kind Regards
Steve
Kind Regards
Steve
