Heidelberg pro9100 SC370-04
  • atech
    • Aug 2010
    • 89
    I got issues regarding Heidelberg pro 9100. It has an error sc374-04. I tried cleaning TD sensor and turn on the machine and got another error sc 370-04. I already cleaned ITB sensor but error still the same. I need your valuable opinion regarding this issue. TIA.
    • 36804
    Re: Heidelberg pro9100 SC370-04
    The -04 of the SC374-04 tells me two things,
    1. You have a color Pro C9100
    2. You have a problem with the yellow PCDU
    I also get the impression that you do not have a service manual or do not know how to use it. If you do not have a service manual, you should not be trying to repair a production machine.
    • atech
      • Aug 2010
      • 89
      You are definitely right. I do not have service manual and only rely on an available manual of Ricoh machines console type. I just wanted to give it a try. Its a challenge for my skills.
        • 36804
        You can put a request in the Service Manual Requests forum and someone might send you one or buy online at service-manual (dot) net. The free site manualslib only has operator manual for this model.
        • Gift
          • Mar 2011
          • 2444
          Both SC codes are related to issues to the ID sensor calibration - perhaps it hasn't be cleaned properly or the PCDU generates low density or image deffects that might trigger this SC codes. I'd also inspect the ITB for defects.
