Ricoh A4 Printer - Bypass Tray Settings
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Hello Team,
    I just want to know if there is a setting from the bypass tray that ignores the size of the loaded paper.
    The current scenario: Customer has a software to print cheque. The image size is in A4 SEF but the output should be in a cheque.
    I wanted to bypass the papersize detection from the printer so that it prints only the text on the image above.
    TIA
    Aye! Cut the crap
  • dalewb74
    • Feb 2018
    • 1107
    Re: Ricoh A4 Printer - Bypass Tray Settings
    set the machine for driver command..
    • keithxxiii
      Just a tech
      • Nov 2014
      • 469
      It was default to Driver/Command, it also prints but the printer throws up an error afterwards.
      The model we are having is P501 in replacement of an HP printer. Tried whatever settings from an HP device, even used the HP driver to print to Ricoh but of course it prints an extra page after that.
      Aye! Cut the crap
      • GIUBOSS
        • 1382
        In the printer settings select "Auto continue" , immediate
        • xbaileix
          • Mar 2020
          • 5
          how about setting the custom paper size in the driver? It works for my customers who print using Chrysanth Cheque Writer
          In Printer Driver
          • Document Size : Custom Paper Size ( 90(W) X 180(L) )
          • Orientation : Landscape
          • Reduce/Enlarge: Zoom (98%)
          • Input Tray: Bypass Tray
