SP C840DN banding in feed direction
  • wyo19
    • Nov 2012
    • 51
    [CQ] SP C840DN banding in feed direction
    I have a C840DN that has a magenta banding issue, meter is 4 k c8,800 replaced the magenta pcdu and still has the problem. Service call is 600 miles round trip, so hoping to some idea on what to bring. I'm thinking a laser unit, IPU or CB power pack. the size is 12x18 and banding is front to back paper feed direction.
  • HitMan
    • Aug 2015
    • 170
    Re: SP C840DN banding in feed direction
    Looks like a yellow banding issue?
    Sent from my SM-G988B using Tapatalk
      • 36694
      You say you replaced the pcdu but what do you mean by that? Did you replace just the Drum unit (PCU)? Was it brand new Genuine Ricoh from Ricoh? Did you replace the developer with genuine Ricoh? Those voids look like toner clumps clogging the doctor blade gap. Are you using after market toner?
      • wyo19
        • Nov 2012
        • 51
        New ricoh drum/development unit assembly we only use oem toner. based on the low meter I might look into your clumping theory...
          • 36694
          FYI, OEM and Genuine Ricoh are not the same. Which do you use.
          • luca72
            • Oct 2017
            • 1673
            can you post the service pm status?.....so we see the situation more clearly.
            "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
            • GIUBOSS
              • 1382
              Have you tried inserting the blue stick into the holes under the pcdu M several times??
              • Gift
                • Mar 2011
                • 2444
                Yup that's DV cloggage and/or a dirty laser glass @magenta.
                If the lines appear at the same postition after swapping the complete PCDU that was quite an expensive way to figure out that this is a dirty laser
                If the lines are moving around or re-appeared short time after swapping the complete PCDU you might deal with clogged toner from the toner bottle, I've seen this every now and then, probably a result of improper storage conditions - usually afer exposing spare toners in direct sun light at the window sill. In this case you have to vac out everything as good as possible, swap the toner, run ~100 high coverage magenta pages and finally swap the dev unit or PCDU again.
