Ricoh drivers for Windows 7
  • PressingPrintz
    • Nov 2022
    • 74
    Hi guys,
    I am trying to find the drivers for a Ricoh MP C3002 for Windows 7 PC.
    Going to Ricoh's website was a dead end as they discontinued offering the drivers for Windows 7.
    I found a few sites that claim they have it however they look sketchy and probably will give you a virus.
    Any suggestions?
    • 36685
    Re: Ricoh drivers for Windows 7
    Ricoh removed all older versions of Windows from their list of Windows OS when Microsoft discontinued support for anything prior to Windows 8.1. Prior to that everything from Win7 on, and I believe XP, ME, 2000 and NT4.1, all used the same driver (32 bit and 64 bit were different). For Windows 11 they only offer 64 bit. If you need 32 bit you will have to use Windows 10. Use the PCL 6 Driver or if you have some really old software the PCL 5C. Do not use anything the says Universal unless you are pooling multiple printers from different manufacturers. Do not use the V4 drivers unless you are using software that is designed to use it,
    Aficio MP C3002/C3002G/C3502/C3502G Downloads | Ricoh Global
    • PressingPrintz
      • Nov 2022
      • 74
      Is it possible to find the original software that came with the unit on a disk?
        • 36685
        If you can find someone who has one.
        • sandmanmac
          • 3967
          Don't use such tunnel vision.
          Pick a PCL 6 Driver for ANY colour box...but let's say a C3003 to keep it similar.
          Any driver will work, and if you look at the version numbers, there is NO difference between Windows 7 thru 11.
          I'm currently running an SP C430 driver to print to my MP C307 at home
          • Saturn
            • Nov 2023
            • 163
            Hi guys,
            Any suggestions?
            I have found a MP C3001 driver CD from 2010. It contains x86 drivers for Windows XP and Vista. PCL5c approx. 3.3 MB and PCL6 approx. 9.6 MB.
            And a MP C3003 CD from 2013, also x86 XP and Vista drivers, PCL5C approx 3,5 MB and PCL6 approx 14,1 MB. All the drivers will also work with the MP C3002.
            I can send them to you by e-mail if you give me an e-mail address.
            I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
            • rthonpm
              • Aug 2007
              • 2849
              The driver model in Windows hasn't drastically changed between Windows 7 and 10 so a driver for 10 should work.
              I'm also hoping that Windows 7 machine doesn't go anywhere near the internet and is on a protected network segment.
              Sent from my Pixel 6 Pro using Tapatalk
              • PressingPrintz
                • Nov 2022
                • 74
                I sent you a private message with my email.
                • PressingPrintz
                  • Nov 2022
                  • 74
                  • Saturn
                    • Nov 2023
                    • 163
                    Check your mail
                    • PressingPrintz
                      • Nov 2022
                      • 74
                      Check your mail
                      • stani
                        • Jan 2013
                        • 49
                        usually you can get the best ricoh drivers for elder machines through the " drivers from windows update" option in the driver installation dialogue.
                        Gesendet von meinem Mi 9 SE mit Tapatalk
                        • Saturn
                          • Nov 2023
                          • 163
                          Hey boss I did not see your email. I checked spam also. Make sure you’re spelling my email with an “s” and not a “z” like my user name.
                          The mail-adress is correct, it's because of the content.
                          The following address failed:
                          yourpressingprints@xxxxxxx.xxx:
                          SMTP error from remote server for TEXT command, host: xxxxx-smtp-inxxxxxx.xxx (xxx.xxx.xxx.xxx)
                          reason: 552-5.7.0 This message was blocked because its content presents a potentia
                          l
                          552-5.7.0 security issue. To review our message content and attachment con
                          I will try to find another way. Do you need to have X86 or X64 drivers?
                          • Saturn
                            • Nov 2023
                            • 163
                            I've send you a PM.
                            • Codex
                              • May 2008
                              • 693
                              i use a Windows 10 driver for all the Win 7 machines and it works without problems...
                              Memento Audere Semper
