Ricoh printers scan to email dalays
  • pjcoxy
    • Apr 2025
    Frustrating problem which I would appreciate some guidance on to assist me to resolve;
    The company I work for have 10 or so Ricoh printers all set up for scan to email. 2 of them (ricoh 2045e and 2228c) often experience long delays in sending a scanned document to an email address, this delay can be 20 minutes up to 12 hours, the document stays on a "sending" status in the queue on the printer display, the facts I have available at this stage:
    all printers on our network our on the lan on a 10.1 IP
    The printers in question have no problems faxing or people printing to them, they have static address's just the same as the other printers
    have changed the name of the exchange server to IP address to rule out DNS issue
    I can scan to email from any another one of our printers to anyone (including my self and the other users who have these delays from the offending printers) no issues
    I have entered my domain logon credentials and password to authenticate and switched on authentication required through the web interface on the printer to see to see if this made any difference - none
    changed the admin email address and sent from address - no difference
    Relay is through exchange where we have the IP's of the printers added in as allowed to relay
    the weird thing is that you scan to a webmail account and it goes through straight away
    I tested it this morning and it took 20 minutes to send, yesterday it took 12 hours, the times it takes seems completely random.
    the settings seem exactly the same as the printers that work fine
    I can scan to a network folder and it seems ok but I have inly tested this a couple of times
    if anyone can help but needs more info please ask
    one good question would be what is it waiting for before it sends?
    its driving me nuts!!
  • aabarnes1
    • Mar 2009
    • 620
    Do the machines you are havig the problem with have the same or indeed latest firmware on them
    Grant me the serenity to accept the things I cannot change.
    • pjcoxy
      I havent checked
      is there any danger of losing the address book on the printers if I do this? There are 10's of address's in the address book and the users would linch me if I lost it!!
      ill have a look on the web in a few minutes and read up about downloading\installing the firmware, Ill give anything a crack but I would be surprised if this fixes it as we havent updated firmware on any of our machines
      another point worth mentioning is that Ricoh come and had a look scanned and sent to webmail and said its working, that was before I got involved the issue so I may call them out again
      thanks for your help
      • aabarnes1
        • Mar 2009
        • 620
        No, you wont loose any address book data doing a firware upgrade, however Ricoh do recommend doing a backup of your existing firmware in case you encounter a problem after the upgrade. You only need to back up the address book if you were replacing the nv ram.
        • Ricoh-ono
          • 339
          How long from the time the last page is scanned until the memory indicator goes back to 100%?
          If it is within a few seconds, then the hangup is on your mail/Exchange server not the equipment.
          Do what you can, with what you have, where you are. ~Theodore Roosevelt
          • pjcoxy
            The memory does not clear back to 100% until the status changes to sent for the job in the scanner menu on the printer. I checked on the exchange server and the message does not reach it until the status on the printer changes to sent.
            the hangup is on the printer for some reason - killer question is what is it waiting for.
            its going cant send now, cant send now, cant send now, cant send now can send now, sent
            so what changes? what criteria has to be fulfilled before it sends?
            thanks for your reply
            • iMind
              Vacuum Cleaning Expert
              • Mar 2008
              • 1116
              • pjcoxy
                I'll give that a go but dont forget it is 2 x printers with the same symptoms
                thanks for you reply
                • iMind
                  • Mar 2008
                  • 1116
                  You could try changing the machines to another switch on your "Rack" or check the RJ45 cables if home made, just my two cents.
                  • pjcoxy
                    Yeh, could do but ping -t drops no packets all day and printing to the printers all day by 20 or so people results in no printing errors and no network related errors in the system logs
                    • Ricoh-ono
                      • 339
                      Try using a smtp relay program on one of you local PC's. If it goes immediately then the hangup is on your mail server.
                      • pjcoxy
                        good idea, I have just installed software to do that on my pc, will try it in the morning
                        I dont see how it can be the exchange server at fault because as soon as the message actually leaves the printer it gets relayed by exchange
                        does anyone actually know what would make the printer wait before it sends?
                        Cheers
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3945
                          The fact that you can scan to a webmail account without issue indicates that a whole bunch of things are working properly.
                          Have you tried doing a packet capture to see the conversation between the MFPs and the Exchange Server? Is it getting hung up in a loop?
                          You can look another machine (that's working properly) to see "what good looks like", as they say.
                          Also, you could set up an XP Workstation with IIS as a simple mail server to see if you get the same results.
                          For whatever it may be worth, there is a custom patch available for the Aficio 2045. The following is from the dealer site:
                          Beta Firmware
                          Acquiring and installing the patch would require your local dealer's assistance. Unfortunately, that doesn't do much for your 2238, though.
                          As other posters previously stated, all firmware must be current. It can also be an issue where some parts of the machine are current, but others are not. Differing version levels sometimes don't play well togrther. (I've been burned by that one several times! )
                          I hope all this helps!
                          • nmfaxman
                            • 1703
                            Check your authentication settings and certificates.
                            Create a local certificate, but don't register it (costs $).
                            Keep authentication to auto.
                            Just something to try.
                            Worked for me once on a remote intranet with scanning.
                            • daverowson
                              Re: Ricoh printers scan to email dalays
                              Good morning, did you ever get the bottom of this issue, we too have a similar problem, scan to email sends the email, but then the printer hangs for 30 seconds waiting for something. exchange has received the email and has no errors, but the printer still waits.
                              Many thanks
                              Dave
