This machine copies and prints beautifully but the scan density/quality is poor. The customer is using Adobe Acrobat "Create PDF" to scan documents. The dpi is set to 600 and the density setting on the scanner is set at the darkest. It appears that the scanned image has a "stepped" appearance which creates a loss of small bits of the image. The image quality is the same scanned from the feeder or the glass. There are quite a few adjustments in scanner image portion of the service mode, it is a bit disconcerting. I have access to a service manual but it hasn't provided much help so far. Attached is a sample scan.
Thanks,
Joe Lopez III
The Copier Doctor
Thanks,
Joe Lopez III
The Copier Doctor
