My company just purchased the new ricoh pro c700ex (still in the demo period) and are having transfer problems that our Ikon techs are clueless about. The problem occurs only on uncoated papers. On coated paper the print is fine but all uncoarted papers have this problem regardless of weight. Basically the toner doesn't seem to be transferring to the paper correctly giving a very patchy mottled look, especially on large solid areas. It happens every time on every uncoated paper but always prints fine on coated papers. The Ikon techs have no clue what the problem is. I am about to return the machine because of this. Does anybody have any suggestions?
Ricoh Pro C700EX transfer problems
JRSC
Attached FilesComment
This is typical of what I see to varying degrees on all machines in this series with uncoated paper. The problem is mostly a paper issue - you always need to use good paper to get good color - but more so with this machine. The toner for this machine is extremely fine in order to produce sharper images with better halftones, but that causes a problem on uncoated paper because the toner particles can fall into the crevasses between paper fibers leaving the "top" of each paper fiber exposed. Typically the first color or 2 deposited on the paper (the last colors placed on the ITB) are worse for this effect, as they tend to fill in the valleys more giving the blotchy colors.
It looks better on a lower thickness setting because the toner isn't melted as far into the page, therefore the tops of fewer paper fibers show through
This is a production quality machine - you either need to use good color paper (which is always coated) or get a lower quality machine. (which will have other annoying issues)73 DE W5SSJComment
JRSC
This is a production quality machine - you either need to use good color paper (which is always coated) or get a lower quality machine. (which will have other annoying issues)Comment
Color copiers are at a disadvantage to begin with - The human eye can only differentiate about 250 shades of grey, so some pretty serious problems in a B/W machine can go unnoticed. On the other hand, the eye can see almost 17 million colors. There is no wiggle room - if something is not perfect you will see it.
Good paper is critical to good color copies. The better the paper, the better the copy. On this machine the slope is exaggerated - The machine is capable of making extremely good copies on the high end, but the process that makes this possible can really suffer on the low end.
Try making the same copies on a lower end machine - chances are you'll notice the same effect to a lesser extent, or you'll have fuzzy copies at a much lower resolution, and the copies certainly won't be as good on the coated paper.73 DE W5SSJComment
JRSC
It sounds like I will probably be returning this and purchasing a xerox 700. Any other suggestions on equipment to replace this?Comment
JRSC
mel
chuckHerb
Equipment to look at
Don't know if you already went with the Xerox, but check out the Konica Minolta 6501 or 65hc series. They got the BERTL's Best Award recently.Comment
If you have the coin...try the xerox 7002..."they" say it rivals offset quality...but then "they" say the 700 is a good box also.Comment
