Ricoh Aficio MP2000; errors SC545, SC542
  • resi
    • 14
    Hi, need help here.
    These two codes keep alternating; when I clear one code in service mode, the other one comes on and so on. I have checked out the fixing unit, cleaned the thermistors, but the cycle goes on.
  • Brave Hart
    • Aug 2009
    • 73
    Hi there!
    Try and replace your thermistor, cleaning them does not always work.
    If you still get the problem check your firmware there is a RTB out on SC 542 as I can remember. If that is all ok then you have a power supply problem I will say.
    But keep checking the thread, the guys here are sharp and will sort you out.
    Good luck
    What? HuH?
    • redstone
      Hello there
      • E Winter
        This can't be that complicated. Check/replace the thermistors, fuser lamp and the thermo piles - these needs to get dashed against the wall/floor hardly if you like to reset them
