Hi everybody , I have a ricoh 2045 that is locked in the toner end condition.
The main problem is that the machine dont go into the "Adding toner" situation after the bottle change , neither after the open/close front door , the bottle motor dont turn on .
1- I dissconnect every front door switch to try if some is "sticky"
2- the motor works fine when I turn it on manually.
3- the copy have enought toner (just a little saturated maybe)
4- I made a clear memory , but after a couple of copies the out of toner signal reapears.
The problem is that the machine is loked as if dont "notice" the open/close door.
Any sugestions ?
PD:sorry for my english
Any sugestions ?
