Aficio MP C2050 Installation
  • Gewch
    • Apr 2025
    Hello Ricoh Experts,
    My company just purchased a Ricoh MP C 2050 outright (with no service contract), and as the System Administrator here, I am responsible for this machine. I realize these may be some pretty basic questions. As a fairly technical guy, my speciality is really in domain administration and network security - not Ricoh installations.
    At any rate, I have set the machine and tested all features. I am happy to say, all features are working; however I have a few requirements for my environment.
    1 - I would like to use "User Code Authentication" to keep track of jobs.
    2 - The machine should be a Black & White machine for financial reasons.
    3 - Color should be allowed to 3 individuals.
    4 - Little to no interaction from the user when installing the print driver.
    I have successfully installed and shared the Printer on one of our Print Servers with the RICOH Aficio MP C2050 RPCS print driver.
    I was able to successfully enable User Code Authentication on the machine through the Web Image Monitor and add entries to the address book and specify Black & White to each user. My problem is when a user adds the Print Driver. They can go into the Printer Configuration and put in their access code, however if they do not switch "Color/Black and White" drop down from Color to Black and White, it will appear their job has printed (even though it has not). This is for requirement 4 above. I would like the job to print no matter what (but just come out in Black & White).
    Please also note that if I go into Printer Properties of the driver on the Advanced Options tab and click the Limitation Settings... button, all choices are greyed out and can not be changed.
    Again to confirm, I would like User Code Authentication and for the machien to print any job sent to it in Black and White unless a color user code is specified.
    Thanks in advance for your guidance.
  • Gewch
    Oh, I forgot to mention.
    I do not want to use "Windows Authentication" because I don't want users having to input their domain information to make a quick copy.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      This is why we charge a connection fee for these. It is poor planning on your part by not getting a maintenance agreement, especially on color machines.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • Gewch
        Well, good thing is they are not rocket science.
        I've developed a work-around in the mean time.
        Thanks for nothing.
        • Venom
          • Nov 2009
          • 765
          You get what you pay for!!!!
          • Gewch
            Well, if the instructions were written by someone who spoke English it would be simple. But, after spending some time going through the Image Monitor, I have found that any high school drop-out would be able to set them up (and repair them too).
            Plug a few cables in here and there, run the setup programs and voila.
            • Venom
              • Nov 2009
              • 765
              I agree, they made it simple enough for the IT department to set up.
              • aaalexxx
                Engineer
                • Jul 2009
                • 51
                if you are using user-code to keep track. dun use rpcs. as it will store the code perm. use pcl instead.
