What high temp grease???
  • nmfaxman
    • 1703
    Ricoh wants $$$$$$ for their high temp grease.
    Anyone know of a good substitute?
    I have used Katun, but it gives off a funny smell.
  • copyaction
    • Oct 2007
    • 985
    CHEMPLEX 710 works great and no smell
    • zed255
      How'd ya manage that?
      • 1025
      I once priced the Kluber Barrierta grease from the local Kluber rep. It was $700 CAD for a kilogram can. Still was cheaper than buying from Ricoh, but really steep still. We just bit the bullet and bought it from Ricoh as we needed it (I didn't have a graceful way to split the can among techs.
      • neergish
        • 177
        We use Castrol high temp bearing grease. Never had any trouble with it. But then not all HT greases are the same.
        High-Temperature Greases
        The castrol is a bentone clay based grease but i have just started using a Clacium Suffonate based grease made by Lubex I think I like it better but that may be only becasue its coloured green both greases are NLGI grade 2.
        Perhaps the benifit I can see from using Barrierta grease is that its a high/low grease but temps on my patch never get that low to be of a concern.
        "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
        • _Brent_
          • Jul 2009
          • 39
          Dupont Krytox GPL-205 is a high temperature grease that is used for fuser bearings, pressure roll bearings, etc. You can purchase at this web-site Krytox lubricants,H-1 certified food lubricants,vacuum pump oil, high temperature lubricants, vacuum grease, remanufactured vacuum pumps, and vacuum components, clean room gloves, clean room notebooks or search the net for your preferred tool/supplies vendor. For specifications please read the attached PDF file.
            • 22916
            I don't know about cost, but the best high temp grease that I've ever used is Molycote HP-500.
            I personally don't care for the Chem-Plex. It drips, and smokes, & stinks. For a long time it was the only thing we had. It worked well on the one-way bearings in the fuser drive sprockets on the Mita DC-513Z/ DC-5055. But there was a few inches of distance from the fuser to the drive pack, so it wasn't quite as hot as it could be. There were a few times that I tried to save some heat roller bearings. At 190C the Chem-Plex grease just ran out of the bearings and smoked off of the heat roller. =^..^=
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3945
              We used the Chemplex 710 stuff years ago - because it was cheap.
              As Blackcat said, it left a lot to be desired.
              • 88hawkfan
                • Jun 2014
                • 76
                Re: What high temp grease???
                Hate to resurrect an old thread, but I'm out of grease and don't want to buy the expensive stuff from Ricoh. Anybody have a good substitute or recommendation?
                  • 36685
                  Krytox is what we've been using.
                  • Tonerbomb
                    AutoMajical Resolutionist
                    • Feb 2005
                    • 2589
                    I've used SUPERLUBE for several years now! no problems with performance or oders, it's cheap and they also make it as an oil. I buy it at Harbor Freight, $5 for a 3oz tube. It's good from -45 to +450 degree's F. It contains PTFE.
                    Mystic Crystal Revelations
                      • 22916
                      Have you used Uniflor 8172? It's the white lubricant for fixing films. It's $0.43 per gram USD off eBay, readily available at Precision Roller at $0.99 per gram:
                      Brochure: http://www.nyelubricants.com/_pdf/Un..._english72.pdf
                      For sale at: *Tech Aids* UNIFLOR 8172
                      • 88hawkfan
                        • Jun 2014
                        • 76
                        Appreciate the input guys, there is a harbor freight around the corner from us so I will give that a try and let you know how it goes.
