Ricoh Aficio 2238c how to disable color printing?
  • valicon
    • Aug 2007
    • 10
    I have a Ricoh Aficio 2238c that I am working on and the client wants to use it as a printer but wants color printing disabled. I cannot find a setting for this. Does anyone know how to disable the color? Thanks.
  • unisys12
    • 490
    from the print driver - lower left corner of the printing preferences. Set the preference to B/W and set as the default. Although it can be changed! So watch out for that.
    Another way to do this, if your a Ricoh tech is to customize the driver for the customer and set it up the same way as mentioned above. This time though, it cannot be changed.
    Yet another way, for copying only... From user tools, system settings, Key Op tools - Set up a user code for color copying. This way, when someone wants to make a color copy and they walk up to the machine and press any of the color selections on the control panel, the machine will ask for the user code.
    Hope this helps!
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • valicon
      • Aug 2007
      • 10
      I did try setting the driver to black only on the server but the user can change it at each computer. Any way around this? I am not a ricoh tech, how can I make a custom driver?
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        The same can be done for printing as well.
        Create a user and enter a user code and just select black and white printing as available.
        Then enter the user code into the relavant printer drivers and make the default black and white for everyone.
        Then instruct all users with that code in their driver that colour prints will not be printed.
        NOTE. The only draw back is a colour print sent in error will not inform the user it has not been printed... it will just be dropped by machine and logged in the printer error log.
        • valicon
          • Aug 2007
          • 10
          I just looked in the manual. Where do I set up a user? I am not really famaliar with this machine. This client has 20 or so people printing from this machine and does not want anyone to print in color. How do i setup what you suggest? Thanks
          • valicon
            • Aug 2007
            • 10
            Okay, the graphic you supplied did not load the first time. Let me try this and I will post back.
            • valicon
              • Aug 2007
              • 10
              I cannot find that screen. How do I access that screen?
              • Cipher
                • May 2006
                • 1309
                123 - system settings - key operator tools - address book management
                new program
                Also a client picking up a printer driver share will inherit the accessories and paper size settings.
                (Those bits should appear greyed out and unselectable on the client).
                The mono / colour settings are on the users printing preferences and these settings don't get inherited from a Windows 2003 printer share.
                Older O/Ss like Windows 2000 and NT4 all settings use to get inherited from the server share.
                • valicon
                  • Aug 2007
                  • 10
                  I found it but someone entered a key operator code and no one here knows what it is! Is there a default or over-ride code I can use to get in?
                  • FRIDGEMAGNET
                    • Aug 2007
                    • 377
                    Service program 7-807-1 set to 1 clears this code.
                    • valicon
                      • Aug 2007
                      • 10
                      How and where do I enter this code?
                      • Tonerbomb
                        AutoMajical Resolutionist
                        • Feb 2005
                        • 2589
                        Nice graphic daz! This is 1 way I deal with this situation, although more complicated for some. On the print server, Load 1 b/w driver with same feature functionality minus color( Ex. Savin 4045) to same port. Load the correct color driver to the same port, then restrict user acess to the color driver through user rights to the color driver from the server. This is all done with cooperation of a very good network administrator. Works great in the right enviroment.
                        Mystic Crystal Revelations
                        • jeffreyozz
                          • Mar 2007
                          • 52
                          Look on the savin website- there is a pcl driver (emulator)editing software that you can use to completely change the driver before installing it onto a client computer. Havent used it in a while but I do believe you can turn off color printing then when you install the new version, it only has the options you selected to begin with.
                          • valicon
                            • Aug 2007
                            • 10
                            I checked the Savin site but there is no listing for the 2238c. Is there another driver that I can use? Sounds like this would be the easiest solution.
                            • valicon
                              • Aug 2007
                              • 10
                              Thanks Daz!
                              Daz! You were right on man! thanks! Thanks to everyone else who responded!
