My company uses the Ricoh MP C6000 and everyone sends their jobs to the copier via the Document Server feature. Is there a way to disable the other features like 'Hold Print', 'Normal Print', etc. so that Document Server is the only option available to them? One of my users refuses to listen and I need a way to just block all his print jobs that are sent incorrectly.
Disable Normal Print? - Ricoh MP C6000
Which driver are you using?
It may be customizable to eliminate all job types but the Doc Server.
Also need to know the OS and if it's 32 or 63 bit.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim Hawkins -
agentcrtr
See page 19: Ricoh White Paper - YAPD Core Based PCL Driver Customization - Powered by Google Docs
Not sure if this applies to all Ricoh PCL drivers though.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - BrotherComment
I think if you put the driver on the server, the print type cannot be changed by the user unless the user has admin rights.sigpic
A+; Network +; PDI+Comment
agentcrtr
I too was looking for something like that for a MPC2050, then I found this site. Still waiting for an answer, though.
Then I found out how to edit the driver manually - problem solved!' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
