How to update MP2000's firmware? (SC997)
  • phabran
    • Nov 2009
    • 32
    Hi there.
    I need your help to update an MP2000 firmware because it's showing SC997 on display everytime that an user press the fax key. But to do this update I will need a pcmcia card but this kind of card is no more available.
    How can I do it? There's some way to do by lan or another way?
    Thanks.
    Patrick
  • Sashko
    • Oct 2009
    • 110
    If FAX option is installed on this machine this means machine has GW controller.
    In this case you can update the firmware with SD card.
    • phabran
      • Nov 2009
      • 32
      It's true. I read the service manual and figured that there is a cover hidding the sd card slot. I will try the firmware update and let's see what happens.
      Thank you!
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        Thank you!
        NOP, PCMcia card needed to upgrade,slots on controller box and bottom back of the machine
