I have been having some problems with a couple MPC6501s not recognizing new toner bags. Now I know the solution to get it to work:
SP 5804 045 and 046 turn them both on at same time until error codes
SP 3410 and select the color affected and switch to 10 instead of 0
SP 5051 Turn off
SP 5061 Make sure reads all ones
Reboot
Make 50 to 60 copies to make sure its loads toner.
The question is how do you prevent this. I could not get a good answer from Ricoh tech support over the phone but that seems to be a common issue with Ricoh tech support, but on one machine it happens every time the machine runs out of toner or shows a near end and replaced early. The customer is not very happy because it leads to plenty of downtime with as much as they print. I have talked to several people and they all heard of the issue but don't know how to prevent it. Any help would be great!
SP 5051 Turn off
Reboot
