ricoh aficio error code "SC542"
  • johnsonisaacnigltd
    • Mar 2011
    • 32
    [Error Code] ricoh aficio error code "SC542"
    Hello everybody, I have Aficio mpc6000 and show error code "SC542" can anybody help me please thanks
  • mikadonovan
    • May 2008
    • 2936
    You have a problem with a fuser thermistor.
    NEVER ASSUME ANYTHING
      • Mar 2011
      • 32
      please what i suppose to do to solve the problem
      • Colonel Bogey
        • Mar 2010
        • 19
        Check that its clean and seated correctly. If still giving problem, then replace.
        To clear the code, use service code 5-810.
        The thermistor you need to check is on the top of the fuser above the hot roller.
          • Mar 2011
          • 32
          aficio mpc6000 error code sc542
          Please can anybody help me with this information, am having problem with my copier aficio mpc6000 and i got some information from ricoh technician said SC542 can be reset in the technical SP Mode of the machine.
          (we are bound by Ricoh rights, regarding the Technical Modes on devices).
          Please order and replace the following part items, should the error not clear.
          AW10 0107 Thermistor
          AW10 0110 Thermistor
          AW10 0114 Temperature Sensor:Upper
          but, i dont know what to do on to reset SP Mode of the machine, any help will be appreciated
          • Colonel Bogey
            • Mar 2010
            • 19
            To Enter and Exit the SP Mode
            1. Press Clear Modes key .
            2. On the operation panel keypad, press 107
            3. Hold down Clear key more than 3 seconds.
            The Copy SP or PM Counter items are displayed. If the printer or
            scanner/printer option is installed, the Printer SP and Scanner SP items are
            also available.
            4. Press Copy SP.
            5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
            screen.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              and the code is SP5810
                • Mar 2011
                • 32
                thank you for all your help, but "COPY SP" is missing on the SP mode screen, what should i do?
                is not showning on the screen
                • Slakkie4x2
                  • Feb 2011
                  • 27
                  try Clear, 1, 4, 3, and the cancel button 2 times.
                    • Mar 2011
                    • 32
                    Please how do i Clear, 1, 4, 3, and the cancel button 2 times?
                    • TonerMunkeh
                      Professional Moron
                      • 3869
                      It'll be System SP.
                      Hit it.
                      • Gift
                        • Mar 2011
                        • 2443
                        I'd recommend to call a ricoh trained tech for this....
                        • TonerMunkeh
                          Professional Moron
                          • 3869
                          Yeah, having re-read the post I'd completely agree. These machines are tetchy at best, having someone who isn't exactly familiar with them will quite severly screw them up, especially with fuser codes. You could damage the fuser more if you reset the code and it pops again.
                          Hit it.
                          • teebee1234
                            • Jul 2008
                            • 1670
                            Follow Bogey's directions (I added a little clarification)
                            1. Press Clear Modes key (Yellow key) .
                            2. On the operation panel keypad, press keys 1,0 & 7 in sequence
                            3. Hold down Clear/Stop (Red key) more than 3 seconds.
                            • The System SP or PM Counter items are displayed. If the printer or scanner/printer option is installed, the Printer SP and Scanner SP items are also available.
                            4. Press System SP.
                            5. Go to SP 5-810 and execute
                            6. Cycle the main power off for 10 seconds and cycle back on
                            While I agree with TonerMunkeh that this is best left to a qualified tech, seeing you're in Lagos is kinda like being in the Wild West and you may have difficulties getting this resolved quickly. As noted, if the error returns after resetting, DON'T RESET IT A SECOND TIME without resolving the cause.
