Ricoh MPC 3500 forwarding faxes to email in a pdf ?
  • Rick
    • Mar 2007
    • 277
    I have this machine set to forward faxes to email but it sends them in a tiff . Is there a way to change this to pdf instead? I looked high and low and dont see where to do this.
  • tonnerboy
    • May 2011
    • 212
    I think you can not send fax-to-email in PDF.
    If You really need fax in PDF you can do fax-to-folder. To make it work you need to change swith 21 bit 3 (Parameter Setting)
    See you
    • teebee1234
      • Jul 2008
      • 1670
      See you
      Even though the manual says this switch is for fax to folder, it also works with forwarding to email. I don't know why they don't specify this with an update.
      How do I specify the file format when sending received faxes to an e-mail or a folder?
      Answer
      It is possible to convert a TIFF file to PDF format when transferring a document received by fax to a PC folder or e-mail address.
      Here, we will describe how to change the file format of a document received by fax.
      Note
      • It is necessary to have already made the settings for transferring fax documents to a shared folder on a PC or an e-mail address.
      1. Press the [User Tools/Counter/Inquiry] button.
      1. Press [Facsimile Features].
      1. On the [Initial Settings] tab, press [Parameter Setting].
      1. Press switch [21].
      1. Press bit [3]. Switch: 21, Bit: 3
        File format for files forwarded to e-mail destinations or folder destinations.
        0: TIFF
        1: PDF
      1. Confirm that the value for bit [3] is selected as required, and then press [OK].
      1. Press [Exit].
      1. Press [Exit] in [Facsimile Features].
      1. Press [Exit] in [User Tools/Counter/Inquiry].
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
        Teebee is right, but some models can only fax forward as a tiff to email.
        Fortunately, this model can do tiff or pdf.
        If you have access to a publication called "GEN-078", this will list which models do and don't support the option.
        I can't post that bulletin here without getting my hiney in hot water.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          Like, oops!
          It turns out that, at least according to the bulletin, that this model DOES NOT support fax forwarding to email as a pdf; I was thinking it did.
          Here is a section of the bulletin describing that. (I think I can do that without angering the copyright gods.):
          • Dexor
            • 223
            Re: Ricoh MPC 3500 forwarding faxes to email in a pdf ?
            Originally posted by KenB
            Like, oops!
            [ATTACH=CONFIG]9680[/ATTACH]
            I currently have 2550 ricoh and even though fax parameters 21/3 is set to 1 it's still forwarding incoming faxes only in .tiff. What gives... ?
            • sandmanmac
              • 3967
              Is the default for a direct "scan to email" on the machine set to PDF? According to the manual, and my experience, the bit switch only applies to folders. Fax forwarding.pdf
