Sc 400 mpc 2051
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    [Error Code] Sc 400 mpc 2051
    Hi all
    I had SC400 on a few of these MPC2051 that I look after for another dealer and I believe they have had some of theirs do the same. We have looked and found no info or bulletins pertaining to this error code. I tried cleaning the ID senors, by physically removing them from the machine. And eventually replaced the ID sensors which did the trick.
    Is anyone else having similar issues with this model, or have any other ideas. The latest machine to have this, has under 3000 (colour and b/w) clicks on it....
    Just out of interest, SP 3-325 is showing 211 which means one of the sensors is misreading, but not every time...
    Look forward to your wise musings
  • Jomama46
    • 2900
    You're sure its a 400? I don't see any reference for it either but 401 and 402 have to do with the transfer HV
    Dang, I just noticed the C in the model. So now I would first try a new ITB or unit and after that the BCU.
    sigpic
    A+; Network +; PDI+
    • tonnerboy
      • May 2011
      • 212
      Make sure this Guide bracket [A] of the ITB are clean.
      Find a few cases where the toner is filed on this bracket [A] and as a result falls into the ID board
      • sharpmind
        • Sep 2009
        • 478
        [Symptom]
        Shortly after switching on there is an audible buzzing noise, followed by SC 400 [ID sensor adjustment error].[Cause]
        Paper Transfer Roller (PTR) motor locking during initial process control checks.
        [Action]
        Remove the Paper Transfer Roller (PTR) motor unit. This is located under the right hand inner cover just below the interlock switch). Refer to the Service Manual for the correct procedure. Clean the positioning sensor and lightly greased cam, ensure that there is free movement of the paper release guide. Install the unit again and check for correct operation.
        [Note]:
        Please make sure the return spring [A] is removed before removing the unit and re-fitted after assembling.
        • Polarbear
          • Feb 2012
          • 1070
          Re: Sc 400 mpc 2051
          We have had a few of these throwing sc-400 a few months after first install. Only one has it happening repeatedly, and I was also of the opinion that it has to be itb related as that is the only source of toner above the id sensors. I communicated this to my field staff, but they seem to disagree.
          Thanks for the info.
          Press the GREEN button!!
          • buttalasso
            Re: Sc 400 mpc 2051
            I had the same problem with the MPC 2050. The wanted to print without the margins and so I shifted it to null in the first side of the sheet. The day after the client called me and told me the machine had sc400. I saw much toner on the bracket [A]. Cleaned the toner, fixed the problem
            • SargeNZ
              • May 2012
              • 263
              Re: Sc 400 mpc 2051
              Plenty of info and solutions in this thread: http://www.copytechnet.com/forums/ri...050-sc400.html
              Clean the ID sensors and the brace above them with the holes that they 'look' through (collects toner from ITB) with alcohol every time you visit the machine. Do not dry wipe as this will generate a static charge and cause them to attract toner.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Re: Sc 400 mpc 2051
                I've had one case of re-occurring sc400 and after trying all the bulletin fixes the only thing that solved it was replacing the complete ID sensor assy.
                It was a while back and no cases at all since...keeping them clean each service call seems to be a theme.
                • Polarbear
                  • Feb 2012
                  • 1070
                  Re: Sc 400 mpc 2051
                  Seems the link above does not exist anymore - does someone know where i can get that info?
                  • CSI
                    • Oct 2008
                    • 73
                    Re: Sc 400 mpc 2051
                    Cleaned the encoder disc behind the itb motor's
                      • 36685
                      Re: Sc 400 mpc 2051
                      It worked for me.
