change login password 5000 mp
  • tecnomarco
    • Jul 2011
    • 203
    Hi, I need help, I bought a ricoh mp 5000 but can not login, I tried "admin" + passoword "" but does not enter someone can suggest something?
  • TonerMunkeh
    Professional Moron
    • 3869
    Re: change login password 5000 mp
    The default login is admin with NO password. If that fails, log in as supervisor with no password through web image monitor, then go to cofiguration and change the password to null in programme / change administrator.
    Hit it.
    • Eric1968
      • 2459
      Default is :
      Username : admin
      Password : leave empty
      If that doesnt work use :
      Username : supervisor
      Then you can change the admin account back to default.
      • totoro
        • 568
        Default is admin and no password. Try that first, if that doesn't work try supervisor and no password. Supervisor will allow you to change the admin password. If that doesn't work then you need to change nvram.
        Totoro
        • tecnomarco
          • Jul 2011
          • 203
          I tried all your suggestions but can not log in!
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            Thats it change the NVram
            • diego_akd2009
              • May 2011
              • 79
              enter the factory menu (yellow - 1 - 4 - 3 - Red - Keep red) enter in copy and resets the sp 5846-46, then try entering the default password
              • tecnomarco
                • Jul 2011
                • 203
                thanks for answered Diego, I tried the procedure you described, but with the yellow 1-4-3 red button held down I can not get into SP Modular
                • mikadonovan
                  • May 2008
                  • 2936
                  Never heard of this. Didn't work for me either.
                  NEVER ASSUME ANYTHING
                  • tecnomarco
                    • Jul 2011
                    • 203
                    thanks ... thanks ... thanks .. mythic! Diego I was able to unlock it! works
                    • mikadonovan
                      • May 2008
                      • 2936
                      I'm still in the dark (as usual). What did you do?
                      • tecnomarco
                        • Jul 2011
                        • 203
                        everything is simple as described by diego, because attention to the red button must be pressed 2 times the second time for five seconds you'll see that enters
                        • rsyarcia
                          Hair Straightener Tech
                          • 711
                          wow.. really?
                          Nobody is perfect..
                          • mikadonovan
                            • May 2008
                            • 2936
                            Worked that time! Thanks for the info.
                            • diego_akd2009
                              • May 2011
                              • 79
                              thanks, be careful what you touch in this menu =) Sorry my English, I hope not to earn the hatred of the technicians ricoh
