Plockmatic SR 90 BM-156
  • Mike Barbee
    • May 2009
    • 39
    [Error Code] Plockmatic SR 90 BM-156
    I have come into ownership of a Plockmatic SR90 booklet maker. It has a BM-156 error code. Can anyone help me with this?
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Re: Plockmatic SR 90 BM-156
    SUBJECT: BM-156
    SYMPTOM:
    BM-156.
    CAUSE:
    Open circuit in the interlock system.
    SOLUTION:
    If a trimmer or Cover Feeder is not being installed in the Booklet maker, an Interlock Jumper needs to be
    installed to each connector plate.
    If a cover Feeder is installed, make sure that the top cover interlock on the SR90 is correctly adjusted.
    • Mike Barbee
      • May 2009
      • 39
      Originally posted by cobiray
      SUBJECT: BM-156
      SYMPTOM:
      BM-156.
      CAUSE:
      SOLUTION:
      When you say each connector plate are you referring to the white connectors one for CF 90 power and one for TR90 power? If so I have an interlock for the CF90 power but not for the TR90 power. Can I use a wire to jump the TR90 power and if so which of the two pins should I connect to?
      • cobiray
        • Mar 2008
        • 1199
        Yes, each of the white connectors needs a jumper (VRC61134 - Interlock Jumper). Also, each of the cf90 or tr90 connectors above the white connectors will need terminators if they don't have them. It sounds like your unit used to have either a cf90 or tr90 installed and wasn't included in the sale to you. I don't think you can just jumper the wires as you are want to do. Neither of the jumpers or terminators have a pin out or schematic which indicates which pin goes where.
        If you call your local dealer I'm sure they can get you what you need.
        • Mike Barbee
          • May 2009
          • 39
          Thanks for your help, I have spent the last three hours trying to find a dealer to help. Do you know of one?
          • mikadonovan
            • May 2008
            • 2936
            These guys are an authorized reseller in CA. Don't know what all they support.
            CFS Bindery Products - Nationwide Bindery Equipment Distributor
            NEVER ASSUME ANYTHING
            • Mike Barbee
              • May 2009
              • 39
              Thank you for the help!
