clear fax memory ricoh 1013
  • patrick045
    • Sep 2010
    • 38
    does anybody know how to erase the fax memory of this machine ?
    so if you print out a fax journal all the fax numbers have gone and the list comes out without information?
    thx in advance
    kind regards
    patrick
  • Meach
    • Nov 2008
    • 128
    Re: clear fax memory ricoh 1013
    SP5-104 Resets Fax back to Factory Settings.
    Resets Bit Switches, User Parameters, User Data in the SRAM, & files in the SAF memory.
    • patrick045
      • Sep 2010
      • 38
      re Meach
      option 5-104 is not available on this model .
      any other solution ?
      rgds Patrick
      • Jomama46
        • 2900
        5-104 in Fax service mode, not copy service mode.
        sigpic
        A+; Network +; PDI+
        • patrick045
          • Sep 2010
          • 38
          option 5104 in fax sp not available on ricoh 1013
          any other solutions ?
          rgds Pat
          • Jomama46
            • 2900
            In system switch 00
            System Switch 00
            No. FUNCTION COMMENTS
            0, 1 RAM Reset
            Bit 1 0 Reset Level
            00No reset
            0 1 Reset Level 2
            1 0 Reset Level 3
            11Not used
            Reset Level 3: Erases all image data files
            stored in the SAF memory and communication
            files (e.g. substitute RX files). This is the
            recommended setting when the SAF requires
            clearing.
            Reset Level 2: This level erases the following
            items in addition to those erased by Reset
            Level 3: own telephone number, bit switches
            (excluding country code), RTI/TTI/CSI, report
            data, programmed telephone numbers
            (Quick/Speed/Groups, service station, etc.),
            NCU parameters, and personal codes. The
            NCU country code is also set to the same as
            the bit switch country code (System Bit Switch
            0F).
            After erasing, the machine automatically
            changes these two bits back to 0.
            No reset: Normal operation
            Cross-reference
            RAM Reset Level 1 (Factory reset):
            Change the RAM address data from
            400005(H) to FF(H), then turn the machine off
            and on. In addition to those items erased by
            Reset Level 2, the clock, country code (the
            default country code is Japan), scan margin
            settings and print registration settings are
            erased. To adjust the country code, you must
            first set system switch 15 bit 2 to 1.
            sigpic
            A+; Network +; PDI+
