Ricoh Fax 3310Le Printout Problem
  • aficiouser
    • Apr 2025
    Hey guys,
    When receiving fax and copying,the printouts has Black vertical lines but
    when i tried to print journal/transaction information it is printing okay.
    Is this a drum unit problem?
    Thanks.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Have you checked to see if the scan glass is dirty?
    Copying would have black line(s) running down the page if that was the case.
    Reports generated by the machine will look ok as the optics are not used.
    Receiving faxes with black line(s) is not unusual either as the faxes machine the other end could have dirty optics.
    Another cause could be electrical noise / bad grounding (check the paper tray grounding points).
    And of coarse a worn PCU or hot roller could also give you a possible line.
    • Scott_Lewis
      • Mar 2007
      • 519
      Originally posted by aficiouser
      Hey guys,
      Thanks.
      DaZ covered the issues with the optics, yours and the sender's. This is where I think you need to look.
      See "Cleaning the Scanner" in your advanced features book, pg 112.
      Side note...... I went on about doing a white level calibration..... good thing I looked at the manual.. no such thing on this beast.
      If you can print the journals and other internal reports without getting any lines, your drum unit and fusing unit are probably ok.
        • 22920
        I agree on all points. Just make sure it's your receptions that have lines, not transmissions.
        If it's receptions, it's very likely that the sender has a dirty Contact Image Sensor or White Level Reference.
        If it's transmissions, it's very likely that your machine has a dirty Contact Image Sensor or White Level Reference.
        You've ruled out any engine problems on your machine, so drum & fuser are fine if reports are fine.
        Anything else would be very unusual. I guess I've seen a few bad CIS. Maybe eight bad CIS in twenty years.
        • aficiouser
          sorry guys for the late reply.i got it fixed.there's was a dirt on the small glass strip under the auto feed.Thanks!
