what to do after new NVRAM INSTALED
  • m_donakov
    • 213
    Hi all a have Sc900 on Aficio 551, it is NVRAM! I changed NVRAM from other machine and now i have bad quality copy? what to do?
    Regrads
  • Gift
    • Mar 2011
    • 2443
    Re: what to do after new NVRAM INSTALED
    1. check out the service manual
    2. don't use the NV-ram data upload/download feature of the service programm if you really have a faulty nv-ram (avoid restoring buggy data) so you should enter all data of the non-default/factory sheet manually
    3. serial number can usually entered only with factory sp access
    • m_donakov
      • 213
      Thanks for you replay but the machine not have factory sheet, and i don know what to do?
      • Gift
        • Mar 2011
        • 2443
        That's unfortunate..
        Can you enter the SP mode if you install the faulty NV ram? In this case you have to write down all relevant SPs (scanner, paper/tray registrations, td/sensor values). You might can save some time of you find onother, working A551 and print out the non-default page - you shouldn't use the values of these but you'll know wich SPs are relevant to write down and wich not.
        • m_donakov
          • 213
          Thanks this NVRAM is from working aficio 551 a firs will tray Laser Beam Pitch Adjustment and i will see
          thanks
