toner chip reset for ricoh mpc2500
  • BATA
    • Mar 2012
    • 27
    hello guys, in case of refilling toner in ricoh mpc2500 , what program to use to reset toner chip to
    cancel the need toner message,without buying chips nor a new cartridge. thank you
  • TonerMunkeh
    Professional Moron
    • 3869
    Re: toner chip reset for ricoh mpc2500
    You can't reset the chips on these machines. Also, don't run non-OEM toner in these machines if you can help it, it makes the toner pumps fail like mad.
    Hit it.
    • Athlontini
      • Jun 2012
      • 269
      In fact, if the Add Toner message won't go away, replacing the black toner pump is generally your best bet.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        BATA take their advise, It is proven. I've been down that road along with them. Toner pumps fail, again and again and again, go OEM with these machines!
        Mystic Crystal Revelations
        • JustManuals
          • Jan 2006
          • 9865
          But he wants to save himself $.05
          • Herrmann
            • Jan 2006
            • 792
            You can set SP3045 from 0 to 1, this would disable Toner end detection at all, but i am afraid, that this will not make you happy in the end
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • kurnal
              • Sep 2012
              • 12
              Hi Guys
              I had to replace black and yellow toners - bought two identical off an amazon supplier, both look OEM in proper boxes etc the black loaded no problems and status bar showed full charge but the yellow keeps reporting no toner. I have got it running again by using your tip to set SP3045 from 0 to 1, but is there anything else I should do or look at?
              Many thanks.
              • ruben
                The New Guy
                • Oct 2012
                • 1204
                Originally posted by kurnal
                Hi Guys
                Many thanks.
                Replace the yellow pump and pipe (or at least clean the current pipe).
                  • 36674
                  Hi Guys
                  Many thanks.
                  Only buy Ricoh toner either from a local Ricoh, Savin, Lanier, or Gestetner dealer or direct from Ricoh. I doubt if the Amazon supplier will send someone out to check the toner.
                  • turbojetboy
                    • Aug 2009
                    • 279
                    Hi Guys
                    Many thanks.
                    Things to do, purchase a full set of devs now - your going to need them in the not too distant future.
                    • kurnal
                      • Sep 2012
                      • 12
                      Thanks very much for your advice. I can hear the pump running and with the reset counter off its copying fine, the old yellow toner did have a residue of rattly hard bits of toner so I guess a particle of solidified toner may have got in to the pipe.
                      In answer to slimslob I only wish I could find a dealer willing to come out and service and repair my machine, lord knows I have tried every agent within a 50 mile radius but to no avail. I don't enjoy having to try and fix it myself. If you can recommend someone who would service and repair a single use low count machine in Matlock I would be grateful!
                      • TonerMunkeh
                        Professional Moron
                        • 3869
                        Ricoh themselves or these guys maybe?
                        Hit it.
                        • kurnal
                          • Sep 2012
                          • 12
                          http://www.derbyofficemachines.co.uk/
                          Nope they were one of the first I tried when my machine broke. Fortunately after failing to find an engineer I was able to fix it with the help the guys on this forum. But I would rather pay someone to do it who knows what they are doing.
                          I left voicemails with Ricoh but they never came back to me, and I collared one of their engineers on a customers site but he just gave me the head office number and they still failed to return my call.
                          Its a cracking reliable machine, the nature of my business means it does very little work but what it does is vital to my business. Yes I bought it second hand but it has been a gem. All the dealers are only interested in selling me a new one.
                          • collme
                            Ricoh tech
                            • 221
                            Basic info
                            2012
                            Sheffield
                            Canon, Ricoh, Lexmark, Kyocera, HP, Toshiba, Sharp, Samsung
                            Contact info
                            • Counsel
                              • Aug 2011
                              • 530
                              Hi Guys
                              Many thanks.
                              Sometimes the chips are out of whack, there was a TSB that if it read no toner in the bottle on a new one basically go to sp3045 and set it to 0 then exit and reboot the machine, then go back to sp3045 and turn it back on to 1 and reboot if needed but usually the bottle ready empty will then read full again. If the bottle reads full but machine says add toner anyway then your pump is probably out or tubes are clogged up, turning off the toner read will only get it running for a short time before the pages get faded out or it starts asking for toner again.
