Green start button stays red
  • haggiss
    • 20
    [Misc] Green start button stays red
    Hi folks
    Green start button stays red cant use machine, suspect HDD as customer had power failure,sorry it's an
    MPC 2800 am I on the right track ?
    Also another customer in same area with a SC863-6 MPC 5000 sounds like it may be a symptom of dirt power?
    Appreciate any ideas
    Cheers Jim B
  • sandmanmac
    • 3968
    Re: Green start button stays red
    For the C2800. I'm assuming that the display also says "Please wait"? Yes, that's likely HDD, but also try re-seating the fax option, and HDD connectors
    I'd also suspect HDD in the C5000.
    Disconnect hard drives in both machines and see if basic copier functionality returns to be sure, then replace if so.
    • nmfaxman
      • 1703
      I would check power supply outputs.
      1 5v output of 3 being dead will lock the machine.
      Saw a pinched 5v tx clock signal wire cause a total lockdown with "please wait".
      Didn't find it until I tried replacing the scanner unit.
      • bjakobs
        • Mar 2010
        • 25
        I would try to format hdd with SP5832-2,-3,-4, -7 and -8 first. If they indeed had a power outage chances are the machine got cut off in the middle of a job, and data "residue" on the hdd then prevents it from reaching ready state.
        • tcs04
          FORMER Techie
          • 1183
          Just try the "IMH" format, normally springs to life and you won't lose any settings. Make sure you purge any print jobs. Can be due to bad data sent to the machine (As stated already!)
          • tinnyjay
            • Oct 2009
            • 654
            Originally posted by haggiss
            Hi folks
            Cheers Jim B
            Close LCT Door lol.
            "Who loves the roses,must also bear thumbs"
