MPC 300 SC240
  • Tuga
    • Mar 2012
    • 35
    [Error Code] MPC 300 SC240
    HI
    my machine MPC300 appears the code SC240 already tested the laser and the IPU board and continues to give the code SC240.
    can help me thanks.
  • Eric1968
    • 2459
    Re: MPC 300 SC240
    What do you mean by "testing the laser and the IPU-Board"?
    The manual says that SC240 is an LD error K. Could be a bad LD-harness, a bad laser unit, or a bad BCU-Board.
    • JustManuals
      • Jan 2006
      • 9865
      Re: MPC 300 SC240
      Paul@justmanuals.com
      • Tuga
        • Mar 2012
        • 35
        Re: MPC 300 SC240
        Hi
        I tetsting in a new machine, the laser uni and the IPU Board
        • sandmanmac
          • 3967
          Re: MPC 300 SC240
          Originally posted by Tuga
          Hi
          Then I'd say it must be a BCU problem as Eric said
          • gnr115
            • 11
            ja tive um caso igual e tive de subs a unidade de laser
            • rickg
              Supervisor
              • Feb 2010
              • 22
              Re: MPC 300 SC240
              check the wire harness near the lvps. had couple of machines where the wire there were rubbing.
              • CableGuy
                Impulse Drive Engineer
                • Oct 2008
                • 417
                Re: MPC 300 SC240
                Maybe try another K PCU unit before you go ordering expensive boards, These things can kick out some odd messages sometimes and lead you up the garden path.....
                • limo
                  • Jun 2008
                  • 101
                  Re: MPC 300 SC240
                  Do you fixed the m/c? what was the problem?I have the same situation.
                  • Tuga
                    • Mar 2012
                    • 35
                    Re: MPC 300 SC240
                    HI
                    No do not solve the problem.But I look to test the BICU in another machine.
                    • limo
                      • Jun 2008
                      • 101
                      Re: MPC 300 SC240
                      For me the problem was with the laser unit.Replace it with one from a defective SPC430 eventhough the p/n is different the unit is the same.
                      • Klydon
                        • Mar 2009
                        • 242
                        Re: MPC 300 SC240
                        Interesting to see this. I saw some sort of alert mentioning that with either 240 or 241 to consider replacing the laser housing unit and the power supply together. No mention of boards being an issue.
                        Not like Ricoh has not been having some "wires rubbing on the frame" issues here lately.
                        • Klydon
                          • Mar 2009
                          • 242
                          Re: MPC 300 SC240
                          I just helped another tech with a SC241. Didn't see any wire issues. Replaced the DC power supply and laser unit and machine was fine.
                          • copier tech
                            • 8095
                            Re: MPC 300 SC240
                            Old post I know! but I have a brand new laser unit for this MPC300/400 & also fits the SPC430, if anyone needs it let me know can ship worldwide.
                            A new laser will fix the SC240 error issue.
                            • bob marley
                              • Jan 2012
                              • 1339
                              Re: MPC 300 SC240
                              HI
                              SC240 already tested the laser and the IPU board and continues to give the code SC240..
                              check harness of the (Bk) LD , could be disconnected or broken
                              Live for yourself and you will live in vain. Live for others, and you will live again
