How to password protect copier function of Ricoh MP C2051
  • seyah96
    • Jan 2013
    • 10
    As the title suggest, how do i make it to ask password before you can use copying.
    I made it only to use authentication, but I don't know where to change the code.
    Any help for this.
  • fbkhan3
    • May 2012
    • 421
    Re: How to password protect copier function of Ricoh MP C2051
    you don't have the user Manual, do yo?
    Well when you set the User authentication on,select the function you want to restrict,like copier,scanner etc,then go to
    address book management,
    New program,
    Username, abc
    key display,abc
    Authentication info
    set password *****
    you can select if for color,Black @ white or for both
    select next
    select the copier again
    done!
    you can even do it via (WIM) its pretty easy though.
    • seyah96
      • Jan 2013
      • 10
      New program,
      Username, abc
      key display,abc
      Authentication info
      set password *****
      select next
      done!
      yeah you got me there.
      thanks alot for this though. +rep for you my friend.
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        Registering a User Code
