How to clear SC 542
  • seyah96
    • Jan 2013
    • 10
    How to clear SC 542
    How do you clear this error.
    I mean the fusing unit is typically brand new.
    Maybe because of the sudden change in temperature?
  • Eric1968
    • 2459
    Re: How to clear SC 542
    SP5-810.
    • seyah96
      • Jan 2013
      • 10
      running this command only once then restart the machine?
      so it must be the temperature change?
      • TonerMunkeh
        Professional Moron
        • 3869
        What's the machine model?
        Hit it.
        • seyah96
          • Jan 2013
          • 10
          it is MP C2051
          • imaginemoko
            unTrusted Tech
            • Jan 2008
            • 289
            Clean the thermistor, perhaps it accumulate some toner.... check the thermostat if its not open... basically i do enter in SP mode then turn it off... but to be more helpful tell us the model... thanks
            fix the customer first then fix the machine... its simple and makes life more easy.
            • seyah96
              • Jan 2013
              • 10
              how do you open the thermostat.
              Also how do you clean the thermistor.
              The machine model is ricoh mp c2051
              • Eric1968
                • 2459
                If you start asking this kind of questions, there's only one advice : "Call a tech!"
                • daveyball
                  • May 2009
                  • 314
                  I agree
                  • fbkhan3
                    • May 2012
                    • 421
                    Totally agree with earlier post,It's not that sort of typical 1045 fuser where you can easily access thermistors,be careful and make sure you know what you are doing,clear it with 5-810 or simply going in SP and restart,if it pops up again measure the line voltage,
                    if that doesn't help follow the Service manual or better '' CALL A TECH''.
                    GOOD LUCK.
                    • andy227
                      • Jan 2013
                      • 219
                      Hehe, thanks for making me laugh guys ! I thought this forum was for techs !!!!
