Ricoh Aficio MP C6000 independent supplier toner cartridge is set
  • bullington
    • Oct 2012
    • 5
    Hi. I am an end user with very little knowledge of my machine. My MP C6000 can copy but not print. The printer shows offline and the display flashes "independent supplier toner cartridge is set". I would appreciate any help provided. Thanks in advance.
  • sandmanmac
    • 3967
    Re: Ricoh Aficio MP C6000 independent supplier toner cartridge is set
    2 completely unrelated issues. Why won't it print? any number of the usual reasons that a machine loses connection, but it has NOTHING to do with the message in the display. (I'm assuming that it was printing previously over the current network?)
    "independent toner": Either you are using generic toner (a very,very bad idea that will inevitably come back to haunt you sooner or later) OR, the toner that is currently in use had been installed previously after a low toner condition, and then replaced with another. Whatever the case, just ignore it. If it's OEM toner, it will go away the next time it is replaced
    • andy227
      • Jan 2013
      • 219
      Agree with everything sandmanmac said above. Ignore toner message, get computer network guy to look at the computer/network set-up.
      • JustManuals
        • Jan 2006
        • 9865
        Paul@justmanuals.com
        • bullington
          • Oct 2012
          • 5
          Thanks sandmanmac. Just got around to following up. Will update you.
          • bullington
            • Oct 2012
            • 5
            Thanks Andy.
            I arranged for a tech. tocheck my network. Will update you.
            • zulufan1
              • Oct 2009
              • 45
              Set Sp 5051-001 to a 1 and power cycle the machine.....No more nag about Independent Toner.....
              • sc430fan
                Hi I have the same message on a SP811DN and also the are ? Marks on both K and C toners.
                all of the toners are genuine, is there a way to reset them and if the codes above work, how do i get into service mode etc?
                Thanks for your help
                • ruben
                  The New Guy
                  • Oct 2012
                  • 1204
                  Buy a service manual, otherwise just ignore the messages, they mean nothing.
                  • sukantha91
                    something about ricoh toner cartridges
                    For a nice and looking for this product/service and I found this one ricoh toner cartridges I am not sure about the quality or the foundation of their offering. Has anyone have looked straight into this before? If you have any other options you know are worth the time to view, please post them here. Thanks!
