ricoh mp c3300 blacked out death certificates.
  • walterman
    • 196
    The problem the customer is experiencing is when the customer tries to make copies of death certificates the mfp copies come out black. The customer has gone over to a copier next door and the end result is a copy with void across the paper. Is there a way I can change the solid black to possibly have a "void" on the copy from ricoh mp c3300. The customer is a lawyers office and needs to copy these certificates. I understand all about the chips and recognition software so please spare me a lecture. I am just wondering if I can change how the ricoh mp c3300 marks the copy instead of having it blacked out.
  • Luther
    • May 2006
    • 682
    Re: ricoh mp c3300 blacked out death certificates.
    try copying it in black and white and enlarging it a little
    • nmfaxman
      • 1703
      I would try to reduce it by 10% increments until it allows it to print.
      • teebee1234
        • Jul 2008
        • 1670
        I believe you have to be at least 15% (maybe 25%) larger or smaller to copy/scan those types of documents.
        • Exok
          • Jun 2011
          • 750
          You would think a lawyers office would just request official copies from the municipal vital statistics office and then charge their client 10x the fee it costs to do that.
          • teebee1234
            • Jul 2008
            • 1670
            Just for goofs, make sure you don't have 'data security for copying" enabled. This is generally an optional feature but worth a check to be sure.
            1. Press the [User Tools/Counter] key.
            2. Press [System Settings].
            3. Press [Administrator Tools].
            4. Press [Data Security for Copying].
            If the setting you want to specify does not appear, press [ Next] to scroll down to other settings.
            5. Press [On].
            If you do not want to specify "Data Security for Copying", select [Off].
            6. Press [OK].
            7. Press [Exit].
            8. Press the [User Tools/Counter] key.
            • techsass
              • Dec 2010
              • 248
              I got this in a memo recently. Death certificates are one of the doc types listed.
              In order to copy checks, you have to enlarge to 155+ or decrease 65- to turn offprotection. If they are still having issues, they are most likely encountering the anti-counterfeiting feature that is present on many of our machines designed to prohibit the use of those machines to counterfeit certain types of documents (money, checks, death certificates, etc). There is a service mode setting (SP 4429) that can allow the machine to copy such documents. This setting causes a grid pattern to appear on the copy to ensure that it is clearly identified as a copy, not the real thing or an attempted counterfeit.
              Last edited by techsass; 08-08-2013, 11:50 AM. Reason: copy & paste left out spaces between some words
              • akewldewd
                • Dec 2012
                • 83
                it is initailly set to a value of 3 so what do you set it to to get it to work? I tried 0, 1 and 2 but it doesn't copy them yet. they still come out black.
                • akewldewd
                  • Dec 2012
                  • 83
                  I tried setting sp4429 to 0, 1, 2 and it still doesn't work. It only ges to three which is the default setting I am not sure if there is something else you have to do or what. Any suggestions?
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1204
                    Which sub-code of SP4-429 did you try changing? All of them? 001 is Copy, 002 is Scanner and 003 is Fax. Have you tried enlarging or reducing the image?
                    • akewldewd
                      • Dec 2012
                      • 83
                      Tried them all and in each code 0-3 and if I reduce 65% it copies but too small. or enlarge 200% it copies but, too big.
                      in my research, I think I may have found a solution to this and will post on it if it works.
                      • akewldewd
                        • Dec 2012
                        • 83
                        5. Press [On].
                        6. Press [OK].
                        7. Press [Exit].
                        I found information relating to the Data Security option and how it makes the maching "black out" the unauthorized copy. and How the instructions you give above would apply with this optional "board" installed.
                        However, I followed these instructions (above) and the data security option is not showing up.
                        According to service manual and information I read if the option is installed the document is "grayed out" and if not watermarks appear in the copied document stating it is a copy. This would lead me to believe the optional board is installed.
                        But when it is installed the option for turning data security on/off should appear in users tools. (according to the service manual)
                        So in theory if data security doesn't show in user tools then the board is not installed and the documents should not be "grayed out". and because they are, it must be installed. So where has the option to turn it off dissappeared to?
                        a cunundrum indeed.
                        also if you remove the board without turning it off in users tools it dissables the machine and service code "sc165" apears. Not sure if the machine is permanently dissabled or if reinstallation of board would get it working again. But I don't want to find out.
                        • ptrflrs
                          Glorified Parts Swapper
                          • Dec 2010
                          • 192
                          for shits try scanning to a pdf or tiff and then printing the scanned image
                          jesus loves you! (everyone else thinks you're an assh*le)
                          street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
                          Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
                          • Ricohtechdude
                            Scan to Document server first and then print scanned file.
