Ricoh Aficio 2105 | SC-101
  • rich1106
    • Feb 2014
    • 21
    Hi.
    I have a ricoh aficio 2105 that showing me a error code sc-101. I have a ricoh aficio 2105 showing me a code error SC-101, before displaying the code makes about 40 or 50 copies until the error and shows 2 black sheets or Half Black and half text.
    the manual shows that failure can be:
    Exposure Lamp defective
    Lamp Stabilizer defective
    Exposure Lamp Connector defective
    MCU Board defective
    SBU board defective
    Dirty Standard white plate
    I change the MCU Board and clean all mirrors, but still shows me the code. Also, I don't know where it is the Lamp Stabilizer.
    if someone could help me or give me some advice to solve this problem would greatly appreciate it
  • JustManuals
    • Jan 2006
    • 9865
    Re: Ricoh Aficio 2105 | SC-101
    Paul@justmanuals.com
    • Bantams
      • Jun 2012
      • 603
      Its the Lamp Stabilizer Board 99.9%
        • 36733
        Agreed, first thing to try. Then the lamp itself.
        • rich1106
          • Feb 2014
          • 21
          HI!.
          Thanks for answer. But what is the stabilizer, where it is. because I read the manual 100 times and I see nothing on the stabilizer. And what can i do to solved the problem ?
          Thanks for your help!
            • 36733
            B070 parts catalog, Optics Section 2, Item 29. AZ500061 Inverter:Xenon Lamp. The exposure lamp plugs into it.
            • rich1106
              • Feb 2014
              • 21
              That is the stabilizer? Really? .
              Then I have to change this board and if it continues to display the error I have to change the lamp. right?
              • tinnyjay
                • Oct 2009
                • 654
                I think the problem is a white plated cable that connect lamp stabilizer with a small board and it moves along carriage with mirrors and lamps.
                I have changed so many of them,because moving all the time it defect the wire.
                "Who loves the roses,must also bear thumbs"
                • rich1106
                  • Feb 2014
                  • 21
                  [ATTACH=CONFIG]24212[/ATTACH]
                  Awesome!. Thanks for your help.
                  I'm going to change the white plated first!. Now I have 2 possible solution.
                  Again, Thanks to all for your Help. If I solved this problem I let you know!
                  PD: Sorry for my english, I think is really bad
                  • rich1106
                    • Feb 2014
                    • 21
                    The Machine work Great!!. Solved Problem !. I Change the Lamp Stabilizer!
                    Thanks to all for your help!
