I have a C3003 set up to FAX FORWARD to a FOLDER, with Printing set to ON, so essentially, FWD and PRINT. It works.
However, in the event of network failure, or someone deleting the folder, etc, the customer would like the FAX to print anyway.
In testing this, by unplugging the network cable, upon failure, it appears the FAX goes into "FAX RECEIVED" mode and does not print.
Is there any way to get the fax to print without turning off FORWARDING and rebooting the copier.
Thanks!
Thanks!
