SC-401
  • mdfurqan2012
    • 194
    [Error Code] SC-401
    I am facing SC401 in ricoh aficio 2090 in Duplex printing/copying, machine did not generate sc401 when I make simplex copy/printing, I check transfer unit in another machine which did not generate sc401 in simplex/duplex. I checked the connections between transfer unit to main machine. Kindly help me
  • 88hawkfan
    • Jun 2014
    • 76
    Re: SC-401
    SC 401 Transfer power pack defective 4/4/2008
    SC 401 Transfer belt or unit defective 4/4/2008
    SC 401 clean bias contact on transfer unit 4/4/2008
    • 88hawkfan
      • Jun 2014
      • 76
      Re: SC-401
      SC401: Transfer roller open error
      Definition [B]
      When transfer bias is applied to the bias roller while the main motor is operating,
      after bias output has started, one of the following conditions exists:
      Input connector is defective
      Output connector is defective
      Possible Causes
      Poor connection between the transfer current terminal and the transfer
      power pack.
      • mdfurqan2012
        • 194
        Re: SC-401
        Definition [B]
        Possible Causes
        power pack.
        Sir I changed complete transfer unit by another one which works perfectly on other machine
        kindly help
        • 88hawkfan
          • Jun 2014
          • 76
          Re: SC-401
          Did you change out the power pack?
          • Wind Cool
            • May 2014
            • 82
            Re: SC-401
            This mostly are Power Pack problem. Just like im facing Ricoh MPC3300 before.
            Try to change and test it.
            • mdfurqan2012
              • 194
              Re: SC-401
              Power pack is locating in transfer unit and i replaced complete transfer unit
              • kannuki2
                • Feb 2012
                • 398
                Re: SC-401
                where did you get the transfer unit? must be a defective one..
                  • 36688
                  Re: SC-401
                  Check the machine side harness that the transfer unit plugs into.
                  • Codex
                    • May 2008
                    • 693
                    Re: SC-401
                    check the drum......i solve an sc 400 error changing the drum, because if the drum is damaged it shortens with the transfer unit
                    Memento Audere Semper
                    • mdfurqan2012
                      • 194
                      Re: SC-401
                      I have 4 machines at one station and the problematic machine is one of them i also check bicu board by swaping it by another machine bicu board
                      • Polarbear
                        • Feb 2012
                        • 1070
                        Re: SC-401
                        I had one of these once where the loom that plugs from the transfer unit into the frame recepticle, would pop out during a run, would cause this error. It took a while to find as, as soon as one fiddles with the transfer unit the contact would return and one could use the machine again, until the plug pops out again.....
                        Press the GREEN button!!
