started with a add magenta light, decided to change entire toner assy from parts copier, then copier ran about 400 perfect color prints then went light and said needed black and yellow toner and black went under toned. re-installed original toner assy and got the black back looking fairly good but now it ask for new yellow toner.
is this a problem with several pumps being out on two toner assy's? having problem forcing on toner pump clutch. marked all for but when i tell it to run all only several turn.
any ideas?
any ideas?
