Hi
I had setup a "shortcut" to scan directly to a shared folder, and the user account password for that share was changed so the scanning gave an authentication error. Even though I changed the password back to the previous value, it is still not working.
I tried to go to the web interface (http://192.168.0.x/) and I just get a 404 error.
I tried:
This had no effect. Any ideas on this? I'd even be open to factory reset and/or upgrade firmware if available and reset.
Firmwares are Printer 1.04, System 1.04, Engine 1.04:02, NIB 6.14
I tried:
- going into the service menu (yellow clear, 1, 0, 7, hold red cancel)
- press 1 for copier
- press 5 for "mode"
- I ensured the web interface was set to enabled (1). Set it to 0 then back to 1.
- Cleared memory for "GWWM"
