In the manuel, sc 558 it says the oil pump and motor need to be replaced but confused? Can it also be power going to the pumps?
Sc 558 error code for ricoh c720
Tags: None
Re: Sc 558 error code for ricoh c720
Goose guide says to check for paper stuck in the oil application unit. -
Oil Application Sub-Unit: Ass'y Part # D016 4480
In my parts catalog it's Fusing unit 6 item 13
It is a Sub Ass'y, inside the Fuser Ass'yComment
check it out and no paper jam inside and the roller is worn a lil will replace and now go to the next steps checking the oil pumps etc can you tell me what is the cleaner to remove the oil dark oil on the machine and on the walls of the machine pleaseComment
also it says to replace the oil supply motor trying to locate that part alsoComment
Hey, sorry, I gave the wrong part number. That number was for the pumps, but for that code the motor number is G1781494
Those motors are pretty solid, so for that code i'd take a close look at the oil supply unit, those units cause a lot of problems.
Sorry for the mix up.Comment
