MX2614 E7-11 Error
  • mabro1974
    • Feb 2013
    • 39
    MX2614 E7-11 Error
    Hi just after some advice ,
    I have had 2 MX2614's in the past couple of weeks with the same error code....E7-11 ( white shading error )
    The error goes away after a reboot for maybe an hour then returns. Both machines have had the same work done on them to try to resolve but with no effect.
    Work done is
    All connections reseated , white plate cleaned and then replaced , scanner lamp replaced , scanner lamp pwb replaced (latest updated one fitted ) , mirror and lens replaced , ccd replaced and scu pwb replaced.
    Any ideas welcome..
  • sharphead
    • Aug 2009
    • 285
    Re: MX2614 E7-11 Error
    Are they on the same site?
    Electrical noise has been known to damage boards not sure whether it would be PCU or MFP
      • 22801
      Originally posted by mabro1974
      Hi just after some advice ,I have had 2 MX2614's in the past couple of weeks with the same error code....E7-11 ( white shading error )
      Work done is
      Any ideas welcome..
      seems you went with the most expensive and time consuming repairs. KISS... what about PCU and dev units? you never mentioned PAGE COUNT on the consumables?
      always start with 1) cleaning 2) consumables 3) boards/assemblies
      • mabro1974
        • Feb 2013
        • 39
        Thanks for the reply , i did clean everything 1st. Then followed instructions as per service manual. Why would dev units cause E7-11 when the fault is white shading error when the copy lamp is reading the white reference plate ??
        PCU sounds a good shout.
        • mojorolla
          The Wolf
          • 2569
          Go into SIM 63 data display. If CCD GAIN value is double digits, CCD needs to be replaced.
          Depending on model, there is an OC and DSPF value....
          • dwarf
            • Oct 2012
            • 168
            maybe run the shading simulation(s)...
            63 1 Used to display the shading correction result. Scanner
            2 Used to perform shading. Scanner
            3 Used to perform scanner (CCD/CIS) color balance and gamma auto adjustment. Scanner
            4 Used to display the SIT chart patch density. Scanner
            5 Used to perform the scanner (CCD/CIS) color balance and gamma default setting. Scanner
