Trying to set this machine up to email from gmail. Need to change the smtp port number. Never seen one of these machines. Can someone tell me how to change the smtp port number. Thanks
Sharp mx-2630. Smtp port number
Re: Sharp mx-2630. Smtp port number
A quick google led me here:
Written by: Jim Haney For organizations in healthcare, education, legal, and government sectors, the answer is yes. Faxing remains a critical method of transmitting secure documents...
You could also log way on the machine itself by logging in as admin and navigating to network settings -
Here's how it should look like :
Primary Server: smtp.gmail.com
Port: 587
Secure Socket Layer: ON
Reply E-mail Address: example@gmail.com
SMTP Auth: ON
Username: example@gmail.com
Password: Ex@mpl3!
Sent from my ONEPLUS A5000 using TapatalkComment
Some of the Aries and Virgo machine require that you log into the webpage to change certain network settings. On these models, SMTP is not accessible through the touch panel.
Failing to plan is planning to fail!!!Comment
Web manager > Login > System Settings > Network Settings > Services Settings > SMTP > Port No.Comment
