Sharp MXM264N Admin Password
  • Tech2002
    • Aug 2008
    • 334
    I've got a machine that when I try to get into Setting I can't - someone changed Admin as the default password. I'm supposed to be able to go to 24-30 and change it but there is no Sub-30. Used to be able to clear all in Sub Serv Mode - but not with this machine.
    Any suggestions? Thanks.
  • mansart
    • 852
    Re: Sharp MXM264N Admin Password
    Is there a security kit? do a 22-10 to determine yes/no
    If yes I believe you are up the proverbial creek
    • Tech2002
      • Aug 2008
      • 334
      Not sure - but I don't think so. You need a Hard Drive for that and this doesn't have one installed.
      • ivan123
        • Oct 2014
        • 54
        You must to set dip switch on mfp board, after that you will see sim 24-30
        • Tech2002
          • Aug 2008
          • 334
          I'll try that - Do you leave switch as is or reset it to the original position?
          • mansart
            • 852
            Power machine off
            Change Dip
            Power on
            Sim 24-30
            Power off
            DIP back to orig position
            Power on
            • Tech2002
              • Aug 2008
              • 334
              Power machine off
              Change Dip
              Power on
              Sim 24-30
              Power off
              Power on
              Appreciated the Assist from All! My issue was finding the correct Dip to turn on - There are together, two switches - 1 & 2, got to have a Paperclip or Jewelers Screw Driver - taking #1 and moving it to I think is left, Opposite of where is sits and performing the above. Worked like a charm. Thank you again!
