Sharp MX-2640N change fax transmission speed
  • ccttechelp
    • Apr 2025
    Hi all
    i want to send fax over VoIP and I need to turn down the transmission speed on this MFP to 9.6kbps.
    I am able to create a fax contact in the address book and set the transmission speed to 9.6kbps and successfully send fax every time.
    I need to make the default transmission speed for all faxes to be 9.6kbps.
    There are no settings in the GUI to do this, how can i set it in the test simulation menu?
    thanks.
  • mansart
    • 852
    Re: Sharp MX-2640N change fax transmission speed
    SIM 66-1
    You must first disable V.34 for TX. Set Fax Soft Switch 27 bit 4 = "1": V.34 invalid in TX.
    Set fax soft switch 29 Bits 3 to 6 = "0100": for 14400 bps or "0001": 9600 bps.
    • repn1999
      • May 2010
      • 310
      make sure ecm is turned off also.
