Mac Printing issue - MX-3071
  • Ceechtay
    • Sep 2011
    • 157
    Hi all,
    We have one Mac user who is having issues printing to an MX-3071. She continuously gets "Toner Low" messages and will not print. The toner is not low and all the other Mac users are able to print without issue.
    User Control is enabled, which is why we need to use the Sharp driver and can't just use a generic driver for B&W printing.
    We have re-installed the print driver and the printer to no effect. We have not yet tried re-setting the printing system on her Mac.
    Anyone else run into this problem?
  • mansart
    • 852
    Re: Mac Printing issue - MX-3071
    If you are not using SNMP on the copier for anything, disable it.
    Network>Services
    • xordi69
      • Jun 2010
      • 200
      And update firmware.
      • TechGeek
        • 158
        Any Luck getting this figured out? I have a customer with a MX-2616N with similar issue were Mac intermittently says printer is offline but is not but still cant print. Let us know what you ended up doing to resolve this issue.
        • guitar9199
          • Sep 2016
          • 1098
          Configuring Macs for printing can be a real pain in the neck... (Or lower). The way I'VE always done it to avoid any issues is....
          1: Run the Driver installer package FIRST!
          2: Add the printer through Apple>System Prefs
          3: Configure as follows.... IP Protocol, Line Printer Daemon (name the queue lower case "LP" -no quotes)
          4: Give the printer a name.
          5: Select Software, then choose the correct model.
          6: Make sure all accessories are active.
          Once that's done, I always go into CUPS to configure everything, including default paper size (it usually defaults to A4), color/b&w, and single sided/duplex.
          ...happy installing!
            • 8061
            I install Mac drivers infrequently, so it is always a challenge for me when I have to do so.
            How do you enter CUPS?
            • TechGeek
              • 158
              First make sure CUPS is enabled
              Open Terminal
              type in: cupsctl webinterface=yes
              close terminal
              Open browser and type: localhost:631
              now you are in CUPS
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3945
                Open Terminal
                close terminal
                now you are in CUPS
                BTW...The ONLY browser that will work is Safari.
                Chrome, Firefox, and others will not.
                • guitar9199
                  • Sep 2016
                  • 1098
                  I've never had an issue entering CUPS with any browser...but since Safari is default I would recommend that.
                    • 8061
                    Enabling CUPS.
                    YouTube
                      • 8061
                      A more detailed CUPS video
                      YouTube
                      • TechGeek
                        • 158
                        Here is an update on my issue with the MX-2616N and the Mac OS. I logged into the machines web page a disabled the SNMPD and SMNP-Trap and it has been working OK for 2 days now. Time will tell.
                        I also found out that they recently updated their switch but customer could not remember if the problem was before or after the switch was replaced. If the issue was caused be the switch does anyone have an idea what on the switch could have caused this phenomenon?
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3945
                          Sometimes switches are programmed to block SNMP traffic.
                          Fairly common, actually.
