Utilizing google drive with single sign on
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Hi,
    i have set up an MX3070 with google drive enabled, also set up a user on the copier to be logged in permanently (device account mode) so that when google drive is selected the user does not need to sign in each time (SSO), however, each time I select the google drive icon, it prompts me for a username and password.
    Do I need an G suite account to allow single sign on from this device?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • mansart
    • 852
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      Re: Utilizing google drive with single sign on
      Originally posted by mansart
      SSO to Cloud Services
      - System Settings > User Control >Default Settings > Store user authentication information for External Connect > Enable or Disable
      That's on by default, but the login screen is shown each time I press the google drive screen, even though user authentication is on, thanks for the reply.
      • Chr15tophe
        • Dec 2011
        • 42
        Dont use device account mode, just set a pin code to log in and cancel the timer for auto logout, that way once you have put in the pin code it will SSO to Google once the user has signed in once. Thats the way we have worked around it..
