sharp mx-3140
  • bruce 49dcs
    • Jan 2017
    • 140
    sharp mx-3140
    my customers mx3140 all of a sudden lost its address book so she tried to log in with the password ADMIN to rebuild the book and it says authentication failed so i tried to go into sims and reset the password but there isnt a sim for that apparently sharp raised security on the newer models and i cant reset it and i dont even know if thats the issue it also has address book error 3000
    i do mostly toshiba i used to be a sharp tech back in the 90's any help would be greatly appreciated
  • Sage632
    • Jul 2019
    • 45
    Re: sharp mx-3140
    I had this happen on an mxm564. Sharp's fix was to back up all user data, replace HDD, update firmware, and reload user data.
    If you don"t have the admin password, you will have to send the IC chips back to sharp for destruction and replacement.
    • driving lots of miles
      • Jun 2016
      • 391
      Re: sharp mx-3140
      I had this happen to a 2640 last week. We had to replace the hard drive and there was nothing left in the old one to copy from so had to start from scratch on the address book.
      • bruce 49dcs
        • Jan 2017
        • 140
        Re: sharp mx-3140
        thanks for responding man although I wish it was better news this one might be over my head im not a sharp dealer just an independent tech
        • Sage632
          • Jul 2019
          • 45
          Re: sharp mx-3140
          Do you hace the tech manual?
          I can get it to you if u need it.
          • Nachoman4life
            • Oct 2007
            • 212
            Re: sharp mx-3140
            admin pw reset is one of the two micro dip switches on the mfp pwb, one takes you to screen calib and the other allows you in admin and service pw reset. the mx3070 series started the no admin reset trend.
            Where the heck is my spring hook?
            • Sage632
              • Jul 2019
              • 45
              Re: sharp mx-3140
              Love your tag line!
              • bruce 49dcs
                • Jan 2017
                • 140
                Re: sharp mx-3140
                hey nachoman i like the dip switch idea
                do you shut off the machine then togle the switch and reboot or do you togle the switch with the power on
                thanks for your help
                • copiertec
                  • Jan 2016
                  • 2184
                  Re: sharp mx-3140
                  Yes, turn off mfp, flip dip-switch, then power on and execute.
                  • bruce 49dcs
                    • Jan 2017
                    • 140
                    Re: sharp mx-3140
                    nachoman
                    sorry to be a bother but i took the back panel off and starred at the main green board for 20 minutes and i cant find the dip switch box also checked the gree board up top by the adf no switches what am i doing wrong
                    • bruce 49dcs
                      • Jan 2017
                      • 140
                      Re: sharp mx-3140
                      also just installed a sharp oem magenta drum and poof the color copies come out with a pink hue dont see a calibration setting like on toshiba when i touch settings on the screen it just says please wait for ever am i crazy or e these machines justr difficult
                      • copiertec
                        • Jan 2016
                        • 2184
                        Re: sharp mx-3140
                        nachoman
                        They are located the mfp board, it's on the left side of the copier under the metal cover. There are two small dip switches, have your magnifying glass handy.
                        • copiertec
                          • Jan 2016
                          • 2184
                          Re: sharp mx-3140
                          You need to follow the calibration procedure in the service manual.
                          • bruce 49dcs
                            • Jan 2017
                            • 140
                            Re: sharp mx-3140
                            I very much appreciate all the input you guys are the best ill let you all know how it turns out
                              • Jun 2016
                              • 391
                              Re: sharp mx-3140
                              if you have not replaced the HDD and updated the firmware you will not be able to get into the settings.
